My N&W class A 1239 (gauge 5", 1 in 10 scale)
Re: My N&W class A 1239 (gauge 5", 1 in 10 scale)
Thank you RussN!
Hello steamers,
With both trucks ready now and mounted under the A tender, I traveled towards Bouveret CH with my friend Raps last week.
They held their anual international meeting (www.swissvapeur.ch), a generous combined 5 " and 7 1/4 " track.
The tender now equiped with the totally new trucks ran safely and stable as intended . Thus we could run the A without trouble. Once we found the right mix of coal for the HT stoker, we could run the engine by exclusive use of the stoker
We met another A 1218 on gauge 7 1/4 " which had been built some years ago. Thus we enjoyed great days!
The lasered parts needed for the brake are constructed and under way. Will take some more time to finish!
Some photos are showing the event.
Best regards
asteamhead
Hello steamers,
Best regards
asteamhead
- Steamchris
Hey WD,
great pictures..good to see your achievement. The Trucks looking very nice.
All the best
All the best
The light at the end of the tunnel could be a train
Health and Safety Notice
has been switched off !
Congrats!
any more pics of the 7 1/4 "a"?
Must be propane fired to run it from behind the tender. I'm guessing built to 1.5 scale?
- JBodenmann
It looks like you had a great run.
Jack
Jack
- Steamchris
Thank you Steamchris, Berkman and Jack!
Indeed, we had a lot of fun there . No difficulties nor derailments with the brand new tender trucks occured . And we were glad to show the HT-stoker working continously to the swiss steam friends once we found the right mix of anthrazit and soft coal. They still run a former French Mikado 1 4 1 R from time to time with museum trains. But they never saw that before as model
Berkman: The A 1218 of scale 1.5 is running on 7 1/4 ". And, she is hand fired by coal But look, her grate and firebox are large enough to run the engine a full circle of about 2 miles with no additional firing necessary. Even with passenger load you cannot use all her tremendeous power
Steamchris: We may meet at Schackendorf this week?
Best regards
asteamhead
Best regards
asteamhead
- Steamchris
Hi WD,
im so sad about to say that i cant come to Schackendorf this year. Silvana's 40th Birthday is at this time, i've got still some work to do in our new house, but we finale moved in the house.
All the best and a save travel at north
Chris
Chris
Helo friends!
Work will not end any soon! Many of the numerous parts of the tender's clasp brake were made by water cut now . Some bolts are to be welded to the ends of the cross bars yet. Some more levers are to come. The brake shoes will then be made as prints or of oak wood (as done before for the loco), whatever will work out best to me.
Best regards by
asteamhead
Best regards by
asteamhead
Pretty work!
I suspect that oak for shoes works quite nicely. Tough wood!
Beautiful work WD!!
I'm glad to see that you guys are all doing well.
Andy Pullen
Andy Pullen
Clausing 10x24, Sheldon 12" shaper, ProtoTrak AGE-2 control cnc on a BP clone, Reed Prentice 14" x 30", Sanford MG 610 surface grinder, Kalamazoo 610 bandsaw, Hardinge HSL speed lathe, Hardinge HC chucker, Kearney and Trecker #2K plain horizontal mill, Haas TL-1 lathe.
Thank you Harold and Andy!
Yes, we are still well here but things are going at a slower pace now due to my age of 75:(
Just now I am doing some maintainance work. First I changed the blast pipes of 9 mm diameter in favour of a pair of reduced diameters of 7 mm. This measure should increase both draft and desired offbeat noise at lower output. The stoker engine needed a closer look after some 200 hours of duty . One piston had a leaky ring and both piston valves showed some wear, too. Easy to be renewed, it`s steam consumption should be reduced to normal then . The mechanics did not need any maintainance yet due to extensive use of ball bearings throughout
Some photos will follow soon.
I found the missing photo on my PC featuring the 7 1/4 " A 1218 at Bouveret: A scene similar to the famous night shot of Winston Link`s "Thunder On Blue Ridge"
Best regards and keep on steaming!
Wulf-Dieter
Wulf-Dieter
Hello friends!
The overhaul of the stoker engine was finished. After changing 2 piston rings and replacing the piston valves I tested the engine by means of a) an old compressor from a refrigerator first. Like this procedure cause you get a good idea regarding losses, friction and propper adjustment of the valves. Then a test followed by means of a real compressor at full preasure up to 120 psi. Impossible to stop the engine's shaft by hand ! You won't believe: This tiny engine delivers up to 1 Nm at the shaft from stop at any position to about 600 rpm - almost a tenth of a HP .
I found it necessary to construct a new oil pump to be installed in the cab. Seems nobody took care of the small one hidden under the cab before.
You see me happy for the stoker showed a tendency to stall in case the boiler preasure felt beloow 100 psi before. The reverse lever had to be used pretty often to start the coal crusher again. Need to test that under steam!
There are some close photos of the engine when open, the valve gear and the refurbished engine.
Best regards
asteamhead
Best regards
asteamhead
