My N&W class A 1239 (gauge 5", 1 in 10 scale)
Steamchris
Re: My N&W class A 1239 (gauge 5", 1 in 10 scale)
Post by Steamchris » Fri Jun 17, 2016 4:31 am
Hi WD,
WoW, im absolutly speechless.
The truck looks really great, what an amazing
work, the Details are so nice.
Now the Boogie?? Power further so....!!!
All the Best
Chris
Health and Safety Notice
has been switched off !
Asteamhead
Post by Asteamhead » Tue Jun 21, 2016 4:06 pm
Thank you Chris for having sandblasting the all welded trailer frame for my A!
Ready for final assembly now I'm eager to do the job and take some photos.
Asteamhead
Ready for final assembly now.
The equalizers, springs and hangers will be inserted through the generous openings from the top. The rocker seats will be fixed by 2 bolts each
Tests were made before, of course!
Bolts will be inserted from the outside
Pedestal caps will be held by 4 bolts each, inserted from top
Steamchris
Post by Steamchris » Wed Jun 22, 2016 1:22 am
WD,
that is a metal art sculpture.
Really amazing!!!
Many work to do for me, hopefully i will doing it
nearly good as you did.
Power further so , with the same fun.
Kind Regards
Chris
Asteamhead
Post by Asteamhead » Thu Jun 23, 2016 6:11 am
Hello friends,
Now the trailer is ready to run (and for the paint shop!).
Some photos are demonstrating the result. Total weight is some 30 pounds. The axles are able to lift/drop +/- 8 mm by means of the equilazers. The rockers will move up to +/- 30 mm left/right while lifting 4 mm.
Now when the job is done, most of the thrill is gone, too. But that's as things are going, for the making is most important (to me). Chris, you will be successful, too, believe me - just a lot of work!
Asteamhead
Leaf springs may be removed by just removing 2 small safety bolts.
Rockers are in left position
Rear axle just down while the front axle is up
Rockers are centered
Steamchris
Post by Steamchris » Thu Jun 23, 2016 7:59 am
Asteamhead,
holly molli, unbelievebel how reallistic the Truck looks.
Outstanding!!!!
See you later Alligator. .....
Regards
Christian
Asteamhead
Post by Asteamhead » Mon Jul 18, 2016 5:09 pm
Hello friends of the N&W steam,
Time to post some more photos of the brake arrangements which are identical for both the front and back engine. There were two brake cylinders for each of the engines. This gave the opportunity to use both air and steam for braking. Cylinders are made identical except two slight modifications:
The air cylinders use o-rings as (tight!) piston rings where the steam cylinders are equipped with a pair of small piston rings made of stainless steel. There is an additional small bore for release of water and condensing steam. Each cylinder is working on just two (of three) pairs of driving wheels.
Thus you get a two circuit -fail safe- brake arrangement!
Asteamhead
A lot of simple parts, made in pairs ...
Constructed for easy assembly and remove
Simple method to adjust the brake from the underneath
Asteamhead
Post by Asteamhead » Mon Jul 18, 2016 5:33 pm
Some more detailed photos of the making
Asteamhead
Made by TIG-welding of three parts each
Just slight different cylinders for use with steam or air. The latter being as tight as possible. A slide disk on the (lose) piston rod is rejekting any dust to be sucked into the cylinder
A bit tricky whith no CNC mill at hand!
Milling in pairs makes fixing by means of the vice much easier
These parts are used as cross links wen finished
kvom
Post by kvom » Tue Jul 19, 2016 6:08 am
Wow!
Asteamhead
Post by Asteamhead » Thu Jul 21, 2016 1:07 pm
Hello friends,
Having finished the front engine now, it could be moved back to it's right position.
The locomotive as shown weighs in almost 600 pounds - without water and some parts still missing.
As next step I will continue with the same procedure to the back engine including the trailer. The optimal connection of the equalizing systems ob both trailer and back drivers may become a little tricky, yet.
Asteamhead
Front engine ready to run.
Back engine to be completed with brakes and some parts, yet.
Trailer ready to run but still to be adepted to the back frame.
Asteamhead
Post by Asteamhead » Fri Aug 12, 2016 6:42 am
Hello builders,
Here are some more photos of making a detail, which might be of interest to others.
For some of the bolts may not be inserted into the cylinder flanges as intended due to hidden steam chanels and other obstacles, one can set them into the covers as blind srews.
Two missing bolts placed in opposite positions should be used to remove a sticking cylinder cover anyway! Using srews to lift that cover is working a lot better than a sharp tool or hammer without damage.
Making those blind srews from raw thread material seems to be easier and more precise than cutting them from hexgonal raw material.
Asteamhead
Blind bolts are set. Two of them may be removed to press off the cover by means of srews. No damage then to the cover!
The raw material is fixed safely by a nut during all work on the lathe
A simple tool holder eleviates cutting
Fixing the visible nut as fast as possible. Then the front of the bolt should be finished.
Cut off the part as final step
Post by NP317 » Fri Aug 12, 2016 10:30 am
So, when do you sleep?
Beautiful work!
Asteamhead
Post by Asteamhead » Fri Aug 12, 2016 1:24 pm
Hello NP317,
Thank you for your kind recognition! Regarding the working hours: Not too a hard time yet but 3 to 4 hours per day, 6 days per week. My target is to achieve the first run under full steam next spring at a US-meeting. Thus time to relax will be later then ...
Asteamhead
A local US meeting, running on schedule - once in a year
