Father & Sons build project: Fitchburg Northern (2.5" scale, 7.5" gauge)
8thscale
Re: Father & Sons build project: Fitchburg Northern (2.5" scale, 7.5" gauge)
Post by 8thscale » Tue Oct 09, 2018 10:21 pm
Donhost4449 wrote:
Thu Oct 04, 2018 12:22 am
As things go, there was a slight bind in the motion. John is studying the rotation to discover the source of the bind.
As it turned out, the rear axle quartering was off .009"
Would you please share more information? What was the setup to measure the error?
I've heard of making an offset key. Even if there are no photos any explaination would be appreciated.
Kimball McGinley
Post by Kimball McGinley » Wed Oct 10, 2018 3:21 pm
I have heard it said that reaming Oilite bushing closes off the pores that make them work so well???
Recommended was pushing through a ball the correct size...
Donhost4449
Post by Donhost4449 » Wed Oct 10, 2018 11:06 pm
I checked with John on this, as he did the work to locate the offending driver. John said "Drivers between centers. Crank pin against chuck jaw. Indicator against other pin. Compare readings."
As for the .009" correction, he likely pressed the wheel off, filed the key slightly, and pressed back together. I had a quartering correction that I did on my LE mogul, and that is all that was required to make the correction. You can see the end result here.
Chris
Building a Fitchburg Northern (build log): www.chaski.org/homemachinist/viewtopic.php?f=45&t=107249
My YouTube Videos: www.youtube.com/user/donhost4449/videos
Donhost4449
Post by Donhost4449 » Wed Oct 10, 2018 11:15 pm
I've never heard that - maybe it does. However, I don't have a ball that is .505"
This is the same method I used to replace the bearings on my LE mogul in 2015, and that locomotive has run hundreds of miles (actual, not scale) since then with no issue.
Chris
Post by NP317 » Wed Oct 10, 2018 11:30 pm
I reamed the Oilite rod bushings on my Ten Wheeler 15 years ago.
Careful inspection under magnification showed that oil holes survived the reaming process.
Those bushings are still looking new 550 miles later.
cbrew
Post by cbrew » Thu Oct 11, 2018 12:50 pm
using a sharp boring bar would do the job opening up the oilite bearing
rkcarguy
Post by rkcarguy » Thu Oct 11, 2018 3:16 pm
I would say that a dull reamer could roll material into the pores of the oil lite bearing, but a sharp one should cut with no adverse affects.
Donhost4449
Post by Donhost4449 » Mon Feb 18, 2019 12:38 am
Wow- time flies! It has been several months since the last update. Progress definitely slowed down: SVLS pumpkin train, Fall Meet, International Railfair, trip to Bitter Creek & Western Railroad, SVLS Santa Train - you get the idea. The first picture is when took our frames out to the club during the pumpkin train for show & tell.
John came over to my house in early November and we continued work on the frames, mostly working on the where the cylinders will attach.
My time working on the project through the holidays was almost non-existent. However, John continued to make progress as seen here.
Donhost4449
Post by Donhost4449 » Mon Feb 18, 2019 12:51 am
There was interest expressed earlier with John's method for machining a radius end. Here is a video of John to further illustrate.
https://youtu.be/0elMZsCM-0w
In addition, I put the boiler on the frame to get a look at what we have so far.
rwmorris
Post by rwmorris » Tue Feb 19, 2019 8:06 pm
Whamo! Just like that... Love that technique for machining the radius on the end.
Donhost4449
Post by Donhost4449 » Sun Feb 24, 2019 5:13 pm
More catch-up from the holidays - I made these back in October.
comebackshane
Post by comebackshane » Mon Apr 01, 2019 2:19 am
Following, great job
