Another CliShay Build
jeanluc83
Re: Another CliShay Build
Post by jeanluc83 »
I decided on a different design for the journal covers on my Clishay. The plans called for a hinged cover that I was not all that wild about. I also really didn't like the prospect of having to tap two small holes in each journal.
The final design might be a bit more modern but on a freelance engine I think it works. It also creates an oil well for the bearings. It will be easy to change if I ever decide to go back to a hinged cover.
Final journal covers
Close up of my redesigned journals on my Clishay
Trying to rush with the wrong setup
jeanluc83
Post by jeanluc83 »
I finally cut the keyways in the main gear and shaft for my Clishay. There is a lot of torque transmitted through this joint so I didn’t want to rely on Loctite alone. The engine crank shaft will get the same treatment.
The most time consuming part was grinding the tool for broaching the keyway in the gear. Overall everything went much better than I expected.
Both keyways cut and the key made
Test fit of the new keyway
Cutting the shaft keyway in my Atlas horizontal mill
Broaching the gear's internal keyway in the lathe
dakine
Post by dakine »
Iam looking for info on a Firetube boiler for the CliShay
Anyone know where some plans are, build info? Thanks
ChipsAhoy
Post by ChipsAhoy »
Modeltec 1994, pg 14 thru 17. Is a set by Ed Warren designed for the CliShay. If you can't find an issue, PM me and I can try to help.
I also have a set of plans for the Big Bertha engine designed to replace the original, it offers more power and eliminates the need to build or use the original transmition. I may can supply the casting for it or offer you 3D printed patterns, or the drawings so that one can print their own.
If you need or want either, please PM me and we can take care of it "offline"... we do not want to continue here because we don't want to hijack this thread.
BTW, this information was provided to me by another member of this board.
Scottys
bill4227
Post by bill4227 »
Had Marty Knox build mine. Works great. We have boiler inspection here in Maryland so consider where you want to run.
Marty_Knox
Post by Marty_Knox »
I have built 4 vertical firetube boilers for CliShays.
Marty_Knox
When I was taking pictures of the VFT boilers I felt they reminded me of something.
I finally figured out what that was - R2D2!
Such nice work!
dakine
Post by dakine »
THIS IS LOOKING GREAT! Have you decided on the type of boiler yet?
I am considering the fire tube type, described by" Modeltec 1994, pg 14 thru 17"
bill4227
Post by bill4227 »
Here is my Clishay with the Marty Knox boiler.
Bill
jeanluc83
Post by jeanluc83 »
So I'm still going to build a fire tube boiler. My plan is to do all of the fab work and then hire out the welding. I'm hoping that it will not be difficult to find someone willing to weld it. My concern is that no one will want to touch it decause it is a boiler.
Work has slowed on my Clishay. There is too much going on the get any real schedule nailed down but I'm making progress. I'm hoping to get the engine running by spring and the boiler built over the summer. Best case scenario the first steaming will be this fall.
ChipsAhoy wrote: Thu Dec 31, 2020 8:59 am... we do not want to continue here because we don't want to hijack this thread.
Please keep sharing. The more info the better.
ChipsAhoy
Post by ChipsAhoy »
My intent was to not flood and divert from your work with a discussion of request for copies, errors and the potential questions of copyright. Not to squelch the flow of info.
