1.5" scale narrow gauge K-36
jeffsmith
Post by jeffsmith » Wed May 27, 2020 12:15 pm
Here are some photos of the cylinder block build for a K-36
Mountaineer
Re: 1.5" scale narrow gauge K-36
Post by Mountaineer » Wed May 27, 2020 1:18 pm
Nice!
Would enjoy more pics of your K36.
Mountaineer.
jeffsmith
Post by jeffsmith » Wed May 27, 2020 2:51 pm
More photos of K-36 Build.
I still need to make the cylinder cocks and the back valve head covers but the cylinders are mostly finished.
kcameron
Post by kcameron » Wed May 27, 2020 8:36 pm
I presume for running on 4.75" gauge track?
Seeing some of the wonderful work you do, it is sad to think it won't be seen except for a black and grimy shadow in a great loco.
-ken cameron
Syracuse Model Railroad Club http://www.SyracuseModelRr.org/
CNY Modelers http://www.cnymod.com/
Finger Lakes Live Steamers http://www.fingerlakeslivesteamers.org/
Member JMRI Developer Team http://www.jmri.org/
mailto: kcameron@twcny.rr.com
In the Upstate New York US area of the world
jeffsmith
Post by jeffsmith » Thu May 28, 2020 10:55 am
Yes it will run on the 4-3/4" track. But it won't be a small locomotive. This is a project that was started back in the mid 80s. I was building a C-25 in 1.5" and a friend was wanting to build a K-36, well he talked me into making all the patterns for it and get it started which I did. Now I am trying to finish one up for myself. The locomotive is about 3/4 done but still a lot to do. Its a long journey when you're building one from scratch and you don't realize that most of those parts you spend hours making will never be seen. I've always been a narrow gauge fan and the Baldwin built K-36 is a classic modern design (for narrow gauge). I will try to keep everyone informed of the progress.
https://www.chaski.org/homemachinist/do ... w&id=77328
Mountaineer
Post by Mountaineer » Thu May 28, 2020 11:02 am
How common is it for the brake cylinders to be hung off the cylinder saddle? Haven’t seen this before- maybe I just wasn’t noticing?
I’m guessing there’s a fair amount more pattern work in a K36 than a K27?
Any chance of pics of the frames/running gear?
L7
Rob Gardner
Post by Rob Gardner » Thu May 28, 2020 6:09 pm
Maybe not more in shear number of patterns but they'll be on average a little bigger for a K36.
Jeff, very interesting to see the two vertical brake cylinders are mounted to the backside of the cylinder castings. Too cool. What parts are you going to tackle next? Main frames?
Rob Gardner
Rob Gardner
Post by Rob Gardner » Thu May 28, 2020 6:10 pm
Jeff, I take it on these outside frame NG engines, the counterweights are probably keyed and quartered very precisely to the axles but the wheels themselves are just pressed on the axles?
Thanks,
Rob Gardner
jeffsmith
Post by jeffsmith » Thu May 28, 2020 6:34 pm
Yes these are outside frame locomotives. One of the attractions for me. The counter weights "cranks" are keyed as are the wheels. The only driver with a counter weight is the main drivers, all others are just spoke. The K-36 has a lot more castings than the K-27. The K-36 and K-37 had the same frame and running gear except for the rear frame and trailer truck. The photo shows the main driver center with counter weight added. Everything is finished on the frame, brake rigging, spring rigging, pilot truck and trailer truck. The boiler is finished just need to roll in the flue tubes. The tender is done, but the hand rails. There is still a lot to do though.
https://www.chaski.org/homemachinist/do ... w&id=77332
jeffsmith
Post by jeffsmith » Sun May 31, 2020 5:13 pm
Here are some photos of the K-36 trailer truck and pilot truck with a flanger added.
jeffsmith
Post by jeffsmith » Thu Jun 04, 2020 5:20 pm
Here are some photos of the rear frame and rear deck plate with the beginnings of the rear cab supports.
https://www.chaski.org/homemachinist/do ... w&id=77436
Short Line Tom
Post by Short Line Tom » Fri Jun 05, 2020 2:05 am
Jeff,
thanks for sharing your beautiful craftsmanship.
I hope, there will be a plan book available for that engine in the near future. :wink:
Cheers
Tom
Each new machine was made on a "used" one.
