Argent Lumber 3 spot
Fender
Re: Argent Lumber 3 spot
Post by Fender » Sun Jan 17, 2021 7:02 am
Here is a page from Baldwin Locomotive Works literature on the Rushton stack. The center section was indeed cast iron, with the upper and lower sections rolled from either steel or copper.
Also, a photo of a broken Rushton stack at the Southern Forest Heritage Museum in Longleaf, LA.
Finally, a drawing from the 1925 Locomotive Cyclopedia of a Rushton stack,
rudd
Post by rudd » Sun Jan 17, 2021 8:34 am
Dick,
I suppose an English wheel would be a good way to do it, but I understand it takes a good bit of practice to use one successfully, my shop is about full, and I don't know anyone that has one. I was tossing around the idea of turning some rolls on the lathe and making a sort of ring roller on steriods.
Fender, thanks, a bit more detail than Mal's drawing. I'm guessing the broken stack is off the scrapped Shay at Long Leaf. What a wonderful place.
Soot n' Cinders
Post by Soot n' Cinders » Mon Jan 25, 2021 7:46 pm
If I remember correctly, the centers on the originals were cast. Maybe get a piece of pipe and find someone with a CNC lathe to turn the shape. This is why I went with a Radley-Hunter on my shay, cones are much easier! That being said, I had the center cone 3D printed from Shapeways and can give you the link to have one printed yourself if it’s about the right size.
-Tristan
Projects
rudd
Post by rudd » Sun Mar 28, 2021 5:01 pm
Update: The experiments with silver solder for joining the steam chest and cylinder are over. I got ahold of some silver solder containing nickel and manganese, BAg-22, same as what the article I had read described. It worked really well on joining (2) 1" x 2" x 1/4" cast iron coupons. I tried it on a full size mock-up of the cylinder steam chest assembly, and just could not get the whole mass hot enough, this with the largest rosebud tip my tanks will support, I think it is a 3. I'd have to lease a larger tank and buy a larger torch body, my shop is made of wood, and this is past my comfort level.
I can get at least 6 No. 10 SHCS's in the joint, Unbrako's shear table gives 1700 lbs each in single shear. I figure that with 100 psi the piston will apply a force of 240 lbs, but the joint needs a safety factor for slug of water/derail etc.
I bought some Deacon 770-L high temp sealant, supposed to be good to 950 degrees and 11,000 psi. It takes heat to cure it, so right now the mock-up is in the oven at 500 for a few hours. Interesting aroma.
Being not married has advantages. I'm curious if anyone else has used similar products.
https://www.jetlube.com/product/deacon- ... g-compound
Post by Bill Shields » Sun Mar 28, 2021 8:38 pm
Interested in how the soldering goes. Doing something somewhat similar => I sent mine to a guy with a furnace who does it for a living..and got back a very nice job that has zero interpassage leaks.
Considering the work involved...for me was the only choice since a solder failure would mean total rework...and I have much less work in my cylinder set than you do...which is really beautiful
Post by Harold_V » Mon Mar 29, 2021 1:26 am
As close as I can come is when I built the adapter for the exhaust stack of my fume hood when I refined precious metals. It had to be heat as well as acid resistant. It was made of Transite (cement bonded asbestos) and had to transition from a rectangle to a round Transite pipe. I made the adapter members tapered and assembled them with a heat curing epoxy. Worked great, and held up for the duration of operation of the refining business (more than ten years) until I retired. I was totally impressed with the product, the name of which I do not recall.
rudd
Post by rudd » Mon Mar 29, 2021 6:40 pm
Bill, I'm curious, were your cylinder sets made of cast arn or bronze?
Post by Bill Shields » Mon Mar 29, 2021 8:12 pm
Steel for cylinders and spreader.
Cast iron liners and phosphor bronze for the valve contact surfaces.
Cylinders, spreader and valve contact surface all soldered together together. Liners slide in with o-ring seals
Post by Glenn Brooks » Mon Mar 29, 2021 10:20 pm
I wonder if you could build a small furnace, using insulated wool blanket material wrapped inside a metal drum?
Put heat into it with one or two 100,000 btu propane weed torches, and silver solder away.
People that stock and sell 1/2” chain usually have plenty really nice size 30 gal metal drums available for free. I built one up this way and have successfully heated a bunch of cast iron wheel sets and sweated them onto axles with such a set up.
A local master craftsmen uses three weed burners with a U shaped wall of fire brick to do repair cast iron engine blocks that are cracked or broken. Just takes a nice reflective furnace and the right quantity of heat.
Iam sure you could braze your cylinder parts together with a similar arrangement. Something to think about, perhaps.
Greg_Lewis
Post by Greg_Lewis » Mon Mar 29, 2021 10:29 pm
I silver soldered some stuff about the size of lemons using a weed burner and a hutch built up from fire brick. The heat coming back at me was intense, but it got the job done. It didn't have the mass of a cylinder block, but the concept is there.
Post by Bill Shields » Tue Mar 30, 2021 6:03 am
I spent $200 and sent it to a professional...even though I have all necessary to build a furnace as described..I lack the experience on something like this to get it right the first time.
I you have an internal leak there is no way to find ot fix it.
Greg_Lewis
Post by Greg_Lewis » Tue Mar 30, 2021 12:32 pm
Good move. Sometimes the best way is to just pay the money and have the experts do it.
