Project: N&W class J on 5"gauge
JBodenmann
Re: Project: N&W class J on 5"gauge
Post by JBodenmann » Fri Feb 28, 2020 11:02 am
Hello My Friends
Magnificent! 611 has always been one of my favorites, and you have captured her beautifully. Bare metal is cool to look at, but a model isn't finished until it's painted. And you are correct, bad painting and finishing can diminish a good model.
Jack
Asteamhead
Post by Asteamhead » Sat Feb 29, 2020 6:34 am
Hello friends,
Be sure the J 611 will look perfect like the Y6b, once it will be painted :!:
Luckily a good friend with proven skills on complicated painting jobs will help to paint the J, too :)
Some photos taken when the Y6b had it's paint just dry will illustrate the very thin and precise coating which is showing all the fine details 8) .
And another photo taken just a year ago shows sustainability of the coating after several years in service.
Have fun!
Asteamhead
Y6b painted
Y6b after finishing the paint job shown with their proud builders
Y6b on exhibition at Dresden in 2019 after several years of service
Andypullen
Post by Andypullen » Tue Mar 10, 2020 7:52 pm
Hey Chris!
See if you can make a detour. PM me and maybe we could meet somewhere.
Andy
Clausing 10x24, Sheldon 12" shaper, ProtoTrak AGE-2 control cnc on a BP clone, Reed Prentice 14" x 30", Sanford MG 610 surface grinder, Kalamazoo 610 bandsaw, Hardinge HSL speed lathe, Hardinge HC chucker, Kearney and Trecker #2K plain horizontal mill.
Steamchris
Post by Steamchris » Mon Jun 22, 2020 12:28 pm
Hi folks,
i hope you all are healthy !
One good thing during the corona time is the fact...you have time to go in basement shop.
So we did some progress on our #611.
The cap fills up more and more....
Some work on the Butterfly door...no castings
Water gauges...left side made to read easily, right side like the prototyp.
The light at the end of the tunnel could be a train ;)
Health and Safety Notice
due to the current economic circumstances , the light at the end of the tunnel
has been switched off !
Steamchris
Post by Steamchris » Mon Jun 22, 2020 12:34 pm
Part 2....
Throttle was finished also....
Inspired of the great work from Anthony #Eccentric Engineer , we build a starter valve , soldered of 6 parts.
At the moment im building the power reverse, wich is working well...tested a few minutes ago...
the piston of power reverse
And an overview of the cab...
All the best
Chris
UPsteamfan
Post by UPsteamfan » Mon Jun 22, 2020 1:34 pm
Amazing work you have done. Is there any castings in your locomotive?
Scott Reinert
Head Something Important
Beefalo Creek Railroad
Steamchris
Post by Steamchris » Mon Jun 22, 2020 1:50 pm
Hey,
thank you,
no castings at all....only wheels are casted.
Regrads
Chris
PeterCraymer
Post by PeterCraymer » Tue Jun 23, 2020 9:03 am
Looking great Chris! I am glad you are making progress and are able to be working again in the shop!
Steamchris
Post by Steamchris » Wed Jun 24, 2020 12:59 am
Hey Peter,
yes, glad that we can meet and work together in our shop. But nevertheless it was so so sad that we both can't met in May this year, because of the Virus. We hope so much that we're able to visit the USA in October, hopefully we can arange a meeting with you and Duncan....finger crossed!!!!
Yesterday we finished the starter valve ,working great:)
All the best
Chris
Steamchris
Post by Steamchris » Wed Jun 24, 2020 11:42 am
Hey Guys,
today, i tested the power reverse of my J. It works great.
All Paets are self made, no castings. It has a flat slide.
All the best,
Chris
Steamchris
Post by Steamchris » Wed Jun 24, 2020 1:00 pm
Part 2....
some short footage of the power reverse....
https://youtu.be/GxBc_mWVtTU
Regards
Chris
Steamchris
Post by Steamchris » Fri Jul 10, 2020 3:45 am
Hi Guys,
some power reverse news. I mounted the power reverse under the boiler, after some minutes of meassuring the right position was found to fully configure the control in both positions. The connections rod between piston rod and steering is only a test rod...all the nice lever are still missing. The pressure at the video was to high...a later test showed it works great at 1 Bar - 14 psi, so the power reverse moves smooth and slow....im happy ;)
https://youtu.be/wB33v5QYdRE
All the best, stay healthy
Chris
