Woodinville Shops
Forum rules
Glenn Brooks
Re: Woodinville Shops
Post by Glenn Brooks » Mon Jul 01, 2019 1:20 am
More or less sitting here all weekend watching paint dry.
More accurately - watching rust dissolve. On Friday, broke down the two existing old rusty trucks and placed the side frames and bolsters in my homemade electrolysis tank. One last set of side frames is cooking off this evening, then everything gets doused with a final coat of phosphoric acid and a new coat of primer.
Hoping the last two side frames will keep working in the tank. The first batch of stuff reacted vigorously to the electrolyte, but the second batch hardly discharged anything while I was watching.... hoping the bath still conducts enuf electrons around the tub to do its job.
I had hoped to make this a quick three day build for this flat car. Now going on four weeks... so it might be appropriate to offer up what is turning out to be my sentiments about finishing this build.
Tomorrow will tell the tale, hopefully.
rkcarguy
Post by rkcarguy » Mon Jul 01, 2019 3:34 pm
Could be quite the opposite problem. A bath full of dissolved rust conducts electricity, and no longer provides a semi-conductive medium that aids in removing the rust in the first place.
Glenn Brooks
Post by Glenn Brooks » Sat Jul 06, 2019 7:36 pm
Ryan, I think I’ve narrowed down the problem to a 1 in a million bad cell in the new battery I bought last week. Two different battery chargers can’t bring the battery over 8.1 volts, even with a brand new battery charger. Iam suspecting the battery doesn’t have enuf current to activate the electrolysis process. Back to Costco for a replacement.
rkcarguy
Post by rkcarguy » Wed Jul 10, 2019 10:49 am
Hmmph, the Costco batteries are supposed to be the good ones still made in the USA. So many are all made in China now.
Glenn Brooks
Post by Glenn Brooks » Mon Jul 15, 2019 1:44 pm
Welded the stake pockets to the frame yesterday. Saw a guy on u tube drill holes in some part for a fab job and weld the fitting to the structure. So tried it out on the stakes pockets. Seems to work quite well. Also the weld spots kind of look like rivets, so good to go, I think! Added an under coat of metal primer and “hung ‘er up to dry”.
Three day job getting close to the finish. End of the month maybe. Still need to mill down my old tight grain fir flooring boards to make the decking.
Finally added a coat of undercoat and “hung ‘er up to dry”
Kimball McGinley
Post by Kimball McGinley » Mon Jul 15, 2019 7:06 pm
Plug Welds!
rkcarguy
Post by rkcarguy » Mon Jul 15, 2019 8:01 pm
Looking good! I've plug welded stuff with both the TIG and MIG before and it does resemble rivets. Of course the flat cars I'm working on have 4 bolts each holding the stake pockets on, which means 36 x 4 drilled and tapped holes:(
Glenn Brooks
Post by Glenn Brooks » Mon Jul 15, 2019 10:28 pm
Plug welds indeed! Thanks guys, good to learn something new.
I like these a lot better than edge welding all around the pockets- particularly with my old Trusty tombstone stick welder.
