Adventures in Railroading!
Forum rules
Glenn Brooks
Post by Glenn Brooks » Fri Apr 30, 2021 10:41 pm
OK, so late this afternoon, sitting on my swinging chair watching the fish swim around in the pond when my neighbor hollers through the woods: Glenn! Doing a controlled burn on your railroad I see? Where’s your hose?
I say, NO! just watching the fish swim around.
He hollers back: WHY IS YOUR TRACK SMOKING?
I walk around the first curve and sure enuf, one of my 4x4 ties is putting out enough smoke to send up smoke signals.
An hour earlier, I finished using my propane tank and weed burner to burn all the weeds off my ROW, around the backyard. My 100,000 btu burner apparently heated up the end grain enuf to ignite some punky wood inside, which then cheerfully burned itself through the center half way to the other end.
Amazing thing, this tie was a new one I put in 3 years ago. Didn’t look like it was rotten thru the middle, but certainly burned cheerfully thru and thru. With the outside completely intact.
Here’s a few pics of the deceased. Look close at the last one, you can see the spike running thru...
10KPete
Re: Adventures in Railroading!
Post by 10KPete » Fri Apr 30, 2021 11:48 pm
Ya trying for an early fire season here, Glenn???
Still to wet on the penninsula here but another month .....
Pete
Just tryin'
Post by NP317 » Sat May 01, 2021 12:26 am
Yikes! Thanks for your neighbor being so observant and friendly!!
There are lessons in this, for sure...
Glenn Brooks
Post by Glenn Brooks » Sat May 01, 2021 1:10 pm
Thought I’d hurry it along, Pete. Get it over before summer hits!
BTW, you mention being on the Penninsula. As in Olympic? I should remember these things... Wondering if you have run across Jessie Banning? He purchased Little Engines and set up shop somewhere outside Squim. He is interested in 15” ga railroading...
rkcarguy
Post by rkcarguy » Mon May 03, 2021 2:02 pm
Yikes, good that your neighbor saw it and alerted you. That would have sucked to have it spread to more ties. That's probably a $20 tie right there with the cost of lumber these days!
Glenn Brooks
Post by Glenn Brooks » Mon May 03, 2021 2:57 pm
Yes, indeed! Fortunately I have a small supply in reserve from three years ago. Shudder to think what they will cost this summer if we build more ROW.
