Mystery bind in wheel/rod motion
Greg_Lewis
Re: Mystery bind in wheel/rod motion
Post by Greg_Lewis » Tue Feb 09, 2021 4:44 pm
The mystery of the century. Perhaps it's time to look at the alignment of the planets. :o
Greg Lewis, Prop.
Post by Bill Shields » Tue Feb 09, 2021 9:38 pm
Why take the wheels off to measure? Put a center turned to the correct diameter on each end of the axle and measure all from there..
If the diameter of the center is the same as the crank pin..it is a no brainer
I would shudder at pressing wheels and cranks on and off.
Steamin
Post by Steamin » Mon Feb 22, 2021 5:36 pm
In the end, I could not find the single one item which causes the binding.
I learned a lot about measuring, measuring accurately and repeatably. Mostly that I could not repeatably measure accurately.
I would say my my efforts to measure pin-to-pin distances with the assembled axles/wheels in the frame was not successful because I did not block the axle boxes from moving in the openings. My skills at measuring the quartering between centers on the mill table improved, but not to a repeatable result. I was most reliable using a single tool such as outside micrometer to measure Pin and Axle box diameters, or the co-axial indicator for the rod and frame centers.
I re-measured the new machine work on rods again, those measurements repeat within 1 thou, which is smallest my mill DRO can report. Each new bushing is 7.00 on center relative to each other, which is what the print calls for and to the best of my ability what the frame openings measure. There is 5 to 8 cumulative error from hole 1 to 3 which I attribute to the coupling rod joint behind #2 which has a little bit of play in it.
The axle boxes in main axle #2 were a sliding fit in the openings. It took pressure to move them up and down, they were not loose. I removed 2 thou on the front and back box openings for both left and right side.
Now the boxes freely float in the openings. This additional clearance appears to give the bind somewhere to go; the wheels roll without issue with the rods on. All the boxes do shift back and forth as the wheels roll around. Before this only #1 and #3 moved, and they did not move together.
Time to move on!
Greg_Lewis
Post by Greg_Lewis » Mon Feb 22, 2021 5:56 pm
Chalk it up to cumulative error. Glad it's finally resolved.
Greg Lewis, Prop.
Post by Bill Shields » Mon Feb 22, 2021 10:22 pm
In general I drill my rod bearings oversize to allow for differences in axle elevations.
An extra 0.005 in bearing clearance goes a long way toward making for a smooth running loco.
Remember. You are building a steam loco.. not a watch.
There are times to be a urologist and times to be a blacksmith. Most of a steam loco is somewhere in between
Builder01
Post by Builder01 » Tue Feb 23, 2021 6:03 am
Bill, I think you mean horologist. A urologist, is something completely different, LOL!
Greg_Lewis
Post by Greg_Lewis » Tue Feb 23, 2021 6:07 am
And I sure hope they don't mix up their tools and techniques! :lol:
Greg Lewis, Prop.
Post by Bill Shields » Tue Feb 23, 2021 10:48 am
Spell correct seems to have changed horologist to something else...sorry
RET
Post by RET » Tue Feb 23, 2021 4:54 pm
Hi Steamin,
Glad you got it sorted out. My hat's off to you. The suspension has to be flexible so the wheels can follow the track.
I have found that as long as that is possible, the locomotive will stay on. It may bounce around all over the place, but it won't come off.
Best of luck.
Richard Trounce.
