Dan, you're not a stoker !
I'm a Stoker. 00122, Mar Eng Art
Alternative fuels:
Coal
Steam coal
Coal Briquettes
(and dam'n all patent fuels !)
wood
Charcoal
Charcoal Briquettes
Oil
Propane
Grain Alcohol
Wood Alcohol
Corn Husks
Corn kernals
Wood Pellets
Pet. Coke
I think that's about all that I've fired. Never tried cherry pits.
Wood Pellets- the question is "how small are your tubes?". Why? Well, if say, you have 7/8" tubes as the big ones (no superheater), the pellets will fly through them. On fire. And rain out. About 6' from the stack. Or say, about where my back used to be...
Yes they provided enough heat for the 4" traction engine. No, they were the worst choice ever for fuel. An experiment that I did once. I suspect corn kernals would do the same thing in the traction engine.
Best by far that I have had was some of the patent fuel from Nanaimo. It was beautiful. Too bad it was last made in about 1952.
Perfect, even sized lumps to hurl through the door on the road with the 4".
Coals are widely variable. I have about 100 lb of Pocahantas, which is being kept for Caribou. Caribou is a bit fussy with regards to coal, not really liking my lifetime supply of Quinsam (BC). The big traction, and the small one, both seem fine with Quinsam, and since I have about 4 tons of it, that's what they get. (as would Robin Hood, when I get 'im back).
Dad swears that the last "good" steam coal he saw was in 1962, presumably with Little Hercules, the steam tractor. All I know is that _really good_ steam coal is about 10% better than "not so good", and that Quinsam has way more Sulphur in it than I really love.
James
