Allen Cylinders maximum bore
I am looking for cylinders with a bore of 2 3/4, stroke 3 3/16. Wonder if anyone has bored out an Allen mogul cylinder that far? I'm trying to avoid making a cylinder pattern. If not Allen, then has anyone else got a suitable cylinder for slide valves? No smoke box saddle required or desired.
Re: Allen Cylinders maximum bore
There is not enough material in the Allen cylinder to go anywhere over a 2 1/4" bore.
I have a set of cylinders that may work for you with no saddle. I will look and see how big they are and let you know.
JD Johnson, Morehead North Fork Railroad Historian
if now, RMI cylinders "MAY" do the job, they finish out a little larger by its an opinion
I went and checked out the set of cylinders that I have.
Unfortunately, they are bored to 2 1/4" and the overall length of the cylinders is 5 3/16". There is not enough material to bore them to the 2 3/4" you wanted. Sorry.
I have had these for several years. Maybe someone here will want them.
Sent a PM.JD Johnson wrote:I went and checked out the set of cylinders that I have.
Mike,
PM Reply Sent to you.
JD
JD
Thanks for taking the effort to check them out. I appreciate that.JD Johnson wrote:I went and checked out the set of cylinders that I have.
JerryK
Everyone,
I have added a photo of these cylinders to this thread if anyone is interested. They come with cylinder heads and steam chest castings.
JD
JD
Color me interested. I sent a reply PM to you JD.
I want to understand the dims of these cylinders and how they mount before committing to them.
Thanks,
Mike
Thanks,
Mike
Mike,
I sent you another PM.
JD
JD
Morning JD, those look like marine or stationary cylinders, is that correct?
