A3 vs Connor Beam vs Raritan
For a first locomotive, which would y'all pick?
Re: A3 vs Connor Beam vs Raritan
I would suggest you look at the new Allen 0-4-0, but I am slightly biased.
- steamin10
A3, Raretan, Allen 0-4-0, Marie Estelle, are all good small builds with lots of run possibilities, in 1.5 scale. They are pretty much the same level of build skill, and present no special challenges that I can think of. Some have castings available, others favor stock. I like the Allen mogul, just a little heavier engine, without a lot of extra work.
Dealers choice: old outline, or more modern? I like 1890's with short cars and bill board ads, home built looking.
Perhaps, but that's okay.Marty_Knox wrote:I would suggest you look at the new Allen 0-4-0, but I am slightly biased.
What scale are you intending to build and what machines do you have to build with?Weibel wrote:For a first locomotive, which would y'all pick?
7.5" gauge, scale doesn't mean crap to me, and at home I have a grizzly G0704+G4000 (on the way) and my clubs full sized mill and lathe.
- steamin10
Scale should matter. 2.5 scale will cost about 3x what 1.5 will, plus the matter of large trailer/truck to haul it anywhere.
2.5 will allow hardware store real parts and plumbing, instead of dollhouse looking, but everything else will cost you in weight and bulk. Consider carefully, and make the right choice for you.
Do you think that if I am asking between these three locomotives that I am really sitting here cutting hairs about scale anymore?
The advantage with the Allen 040 over the A3 and Raritan in 1 1/2 you would not have to scale up the plans from 3/4".
Wayne
Wayne
You might look at Trainman's new engine "kit".
- Benjamin Maggi
The A3 and the Allen Models 0-4-0 look much different than a Beam Engine, and a bit different than a Raritan. Since you will be "stuck" with it for years, through good times and frustrating times, pick the engine YOU like best. Also, if you are planning on running on tracks with steep grades that may influence your decision.
Well quite frankly considering 2 of the 3 listed locomotives in the title of this post are, AS DESIGNED, 3/4 scale locomotives are we supposed to guess?Weibel wrote:Do you think that if I am asking between these three locomotives that I am really sitting here cutting hairs about scale anymore?
Ken-
