Watch me cut my boiler in half! **Part 2 just added 3/13**
- Donhost4449
On January 1, 2015, I had a setback that might have resulted in not having steam at the Triennial. However, some awesome friends extended a helping hand, and we were able to play at the Triennial after all. This video is "Part 1" of the overhaul, and documents the work done on the boiler.
In addition to the boiler work, I took the opportunity of having the boiler off the frame to address a few other issues. The photos and videos from that work are currently being edited, and will be "Part 2." I should have that video done in the next few weeks, and will post it here when it is ready. Enjoy!
https://www.youtube.com/watch?v=yWBwGd85-NY
Chris Donhost
Vacaville, CA
Chris Donhost
Vacaville, CA
Building a Fitchburg Northern (build log): www.chaski.org/homemachinist/viewtopic.php?f=45&t=107249
My YouTube Videos: www.youtube.com/user/donhost4449/videos
Re: Watch me cut my boiler in half!
Some guys in central Fl. have done that and said it was the easiest flue job they ever did.
Fred V
Pensacola, Fl.
Pensacola, Fl.
Fascinating, if not a bit scary!
As a novice, I'm curious about tube rolling. Does rolling a tube flare the ends to a watertight seal, or does one roll the tube and then weld?
- Donhost4449
Rolling flares the tube into the tube sheet. The photos here show the tube before/after the rolling.PRR5406 wrote:Fascinating, if not a bit scary!
- Donhost4449
I think the timeframe from failure to hydro speaks to this. I have never done one before, but John shared with me his reasoning for suggesting this route. He said that removing the old tubes is a pain in the butt, and is an easy way to damage the front/rear tube sheets. By cutting in half, the tubes easily came out with a little help from a small mallet. There was no damage to the tube sheets. I reamed them to ensure the best seal possible with the copper.Fred_V wrote:Some guys in central Fl. have done that and said it was the easiest flue job they ever did.
For those interested, here is the link to the sight glass thread:
http://www.chaski.org/homemachinist/vie ... =8&t=95146
In addition, here is a video I shot while helping my friend Stathi roll tubes in his 1:1 scale Porter 0-4-0 locomotive, the Santa Cruz Portland Cement #2. Having done both, I can tell you we have it good in 1/8 scale! I was beyond sore after rolling tubes in his locomotive all day.
Chris
I cut industrial heat exchangers in half to retube them for years....done a couple of small loco boilers this way also.
It is by far the easiest way to retube a boiler..
- steamin10
I have to say that before seeing the vid of the dissected boiler, I was of a mind that this was dead wrong, to retube a boiler.
After looking at the vid, and with my past experience, it makes total sense, as long as a simple cut is possible, on the shell.
Kudos, as I am a hard one to convince.
Dave.
Dave.
Great video, thanks for putting it together and sharing with us!
Bill C.
Bill C.
on bigger exchangers, we used to weld clips on the outside, and create 'bridges' that would be used to realign things as we welded them back together.
this is because we frequently used to cut the shells with a torch...sometimes having to cut around pipes entering the shell from the side...and 'straight cuts' were just not possible.
- Donhost4449
The clips are a good idea. We sprayed a white strip and etched a straight line on the sides, top & bottom.Bill Shields wrote:on bigger exchangers, we used to weld clips on the outside, and create 'bridges' that would be used to realign things as we welded them back together.
The guys in Fl. put punch marks in 3 spots around the boiler and spaced them 1/2" apart. These let them align the 2 pieces exactly the way they were before cutting.
Fred V
Pensacola, Fl.
Pensacola, Fl.
- Donhost4449
As promised from the original posting, I have completed "Part 2" of the locomotive rebuild project. Enjoy!
I know for some the embedded link doesn't work, but this should: https://www.youtube.com/watch?v=I90lpHcrWCk
Chris Donhost
Chris Donhost
