Quick-Disconnect fittings for air brakes (Part # needed)
Re: Quick-Disconnect fittings for air brakes (Part # needed)
I expect that nothing more than compression of the O ring holds them together. The pins are likely located such that the O ring is compressed when the two pieces are assembled. In theory, there is little to no load on the coupling, so it has little reason to disconnect. Air pressure pushes against the sides of the pins, so it doesn't cause the coupling to disconnect. A rather clever design, really.
10KPete
Post by 10KPete »
That was my 'guess' Harold, but I hate not really knowing...... :shock:
Pete
Just tryin'
cbrew
Post by cbrew »
Morning, Harold Nailed it, the o rings have a enough compression on them and create a decent amount of friction.
10KPete
Post by 10KPete »
Well, OK, now I know. I guess I was holding out for some neat little trick. :lol: Simple is better!
Thank you,
Pete
Just tryin'
cbrew
Post by cbrew »
no black magic here :)
Fred_V
Post by Fred_V »
I found my answer about water disconnects. Here are some with 1/4" and 3/8" hose barbs; really cheap.
http://www.usplastic.com/catalog/item.a ... &catid=743
Fred V
Pensacola, Fl.
FLSTEAM
Post by FLSTEAM »
Ah, come on I live just up the road from the Magic Kingdom.
JB
cbrew
Post by cbrew »
Fred_V wrote:I found my answer about water disconnects. Here are some with 1/4" and 3/8" hose barbs; really cheap.
I use these for my water and propane connections.
going on 6 plus years with flawless service
http://www.ebay.com/itm/like/3115046662 ... noapp=true
Phil Tucker
Post by Phil Tucker »
10KPete wrote:Phil, I"m glad I was able to find them. I did wonder about the pull apart as I know they are not at all designed for that. They don't break or crack??
Pete
They will tolerate a few cycles of being yanked apart. However, my understanding is that they will eventually break if this is done on a regular basis. I always disconnect mine properly by twisting the connection and have never had to replace a fitting yet.
Phil Tucker
cbrew wrote:I use these for my water and propane connections.
Great tip! These looks like the quick-disconnects made by Rectus in Germany which, unfortunately, are nearly impossible to get hold of now.
Donhost4449
Post by Donhost4449 »
Chris-
Would you share a picture of how you have them set up between your tender and locomotive? I am also interested to know what type of hose you use.
Thanks,
Chris
Building a Fitchburg Northern (build log): www.chaski.org/homemachinist/viewtopic.php?f=45&t=107249
My YouTube Videos: www.youtube.com/user/donhost4449/videos
Fred_V
Post by Fred_V »
And, how long are they when assembled? I would think that you could machine the threads into a hose barb.
Fred V
Pensacola, Fl.
