Cast Iron Valve Rings
Moderators: cbrew, Harold_V
one_inch_railroad
Post by one_inch_railroad »
A friend of mine was wondering if there are any suppliers of cast iron valve rings on this side of the atlantic now that Coles is no longer in business. He is looking for rings that are 1" by 3/32.
prlawiii
Re: Cast Iron Valve Rings
Post by prlawiii »
These people have cast iron piston rings, 1" diameter by 1/16 by .051 wall.
https://www.deboltmachine.com/products/ ... g-051-wall
Herman
Just starting an Allen Mogul
renewing a Marie Estelle
BClemens
Post by BClemens »
Diminutive sized rings are not so awfully hard to make.... even gapless ... along with the necessary heat treating. There are many written texts about this in the IC engine world.
BClemens
ebtfan
Post by ebtfan »
I obtained my cast iron rings from this company:
hydra-seal.com
They have an ordering form where you can input your request and they will offer a quote.
Dan
Marty_Knox
Post by Marty_Knox »
Otto Gas Engine Works in Maryland has them. www.ringspacers.com
BClemens
Post by BClemens »
I will NEVER make another ring! Had no source... That is if the model isn't a 'close to scale' and the rings needed aren't some odd ball size but that was usually the case building IC engines.
THANKS!
AMc
Post by AMc »
WWW.HERCULESUS.COM
1" to 12" cast iron piston rings
Do a a search for SPR- Example:SPR-2000 will get you a 2"
On line ordering too.
John Landrum
Post by John Landrum »
Try the folks at Grove rings up in Milwaukee. You may have a minimum order, etc. but they are very capable and helpful.
VENDOR
Grover Corporation
2759 South 28th Street
Milwaukee, WI 53234
