Page 1 of 1
Injector Orientation
Posted: Sat Apr 15, 2017 1:25 pm
by RickBarb
Is the operation of a steam feed water injector affected by the orientation of the injector?
Rick
Re: Injector Orientation
Posted: Sat Apr 15, 2017 2:59 pm
by Bill Shields
considering that most of them have an internal check valve that assumes gravity is 'thatta way'...I would say yes.....
Posted: Sat Apr 15, 2017 3:33 pm
by Pat Fahey
Hi RickBarb
Here's and article written by Bill VanBrocklin that also mite you, Pat
- Article by Bill VanBrocklin , Pat Fahey collection
Posted: Sat Apr 15, 2017 5:10 pm
by Builder01
Perhaps this article (image) could be posted at a higher res? It's not really possible to read otherwise. Looks interesting though!
David
Posted: Sat Apr 15, 2017 5:56 pm
by Pat Fahey
Hi Dave
I tried to get a higher resoultion on Bill's article , but file becomes to big, sorry , Pat
Posted: Sat Apr 15, 2017 6:24 pm
by 10 Wheeler Rob
Super Scale economy injectors have a spring loaded check valve and I usually see them mounted vertical. Mine is mounted that way and works just fine.
Rob
Posted: Sat Apr 15, 2017 6:56 pm
by Builder01
Hi Pat,
Thanks for the PM!
David
Posted: Sat Apr 15, 2017 7:49 pm
by BAdams
RickBarb,
In whatever web browser you are using right click on the image and select open in a new tab.
Hover your mouse over the image and you should see a plus sign, if you click it will enlarge a bit more.
While on that tab you can also press the "Ctrl" key and your "+" key which will zoom your entire browser in (a big help when you forget the glasses down stairs
Brook
Posted: Sun Apr 16, 2017 9:13 am
by Steven E. Kuhn
Or just left click over the article and it opens to read just fine. But right click and open new tab does achieve a larger copy.
And thank you for the article.
Steve Kuhn
Posted: Sun Apr 16, 2017 9:51 am
by Builder01
Thanks for all the help guys!
David
Posted: Mon Apr 17, 2017 6:46 am
by dregs484
If the check valve is spring loaded then I does not matter which way it is. Horizontal or vertical. I have a pair of superscale economy's mounted horizontally in my cab, they have been working fine for the last 7 years.
Regards
Greg
