Steam dome seal
Re: Steam dome seal
FLSTEAM wrote:Another direction would be to cut the studding flange out then true it in the lathe again.
Re weld it back in place but this time be sure to tack it in place with lots more tack before the root pass.
John B
That sounds like way more work than setting up to correct the non-flat mating surface.
Messing with boiler welding would be my last choice, based on my skill levels.
And I would not expect to ever get a good seal on a surface with 0.010" gaps.
Take the time and effort to mill it flat, that's the best long-term solution. Worth the effort.
Just my thoughts.
Greg_Lewis
Re: Steam dome seal
Post by Greg_Lewis »
If all you are dealing with is a .010 gap, I'd explore sealing options. Ten thou just doesn't seem like that can't be solved with gaskets. In my Model A Ford days, I don't think we ever had a head-to-block seal that was even close to .010. I'd look for some FelPro gasket material at a good auto parts store. FelPro makes a variety of gasket materials and there are some that look like they'd be just right. I'd also try some Key Graphite Paste on the gasket. Another option would be a gasket from a piece of annealed copper sheet. Put thin gasket paper on both sides of that. I'd also spend some time on the McMaster site looking at their gasket materials https://www.mcmaster.com/#standard-gaskets/=19xsi3i . There's a lot more out there than just paper.
Greg Lewis, Prop.
Kimball McGinley
Re: Steam dome seal
Post by Kimball McGinley »
If I could not get it on the mill, I think I would mark, file, check, mark, etc. to get is as close as possible. Auto parts stores sell a product called Plastigage, used to check the oil film clearance between the crank and rod big end. It is a plastic string that is placed in the assembly, which is then tightened. When disassembled, the width of the smashed string corresponds inversely to the clearance it saw. This might be a great help, and they are very cheap. I think they come in various ranges.
RET
Re: Steam dome seal
Post by RET »
Hi,
I assume this is for 7 1/4"/7 1/2" gauge. If so, I would take the dome, chuck it in the lathe and cut a groove for an "O" ring inside the bolt circle. If this is for 1/8" scale, you could use a 1/4" thick "O" ring of the appropriate dia. to fit in the groove. For a 1/4" thick ring, leave it about 1/16" "proud" of the surface. This setup should have no difficulty in sealing the leak even if its more than .01"
I use "O" rings a lot to seal various things, fittings etc.
Richard Trounce>
apm
Re: Steam dome seal
Post by apm »
I am reading through the replies and they all sound like way overkill. When I finished welding my steam dome it didn't look to nice. Like others getting the boiler mounted on the mill was a royal pain so I took the angle grinder cleaned it up as much as I could. Then I got a 1/8" thick Garlok gasket https://www.mcmaster.com/#9472K623 and some Permatex Indian head schellac at the local auto parts store and it doesn't leak.
0.010" would be wonderful compared with what I must have. The only minor issue is that with the permatex any time you break the joint plan on installing a new gasket. None the less they are cheap enough to get and for me was far better than figuring any way of getting the whole boiler onto the milling machine.
Re: Steam dome seal
Post by Bill Shields »
why don't you try a 1/16 thick, annealed copper gasket?
0.010" is nothing to take up (been there, done that....)
Dick_Morris
Re: Steam dome seal
Post by Dick_Morris »
The full-sized 1944 Consolidation we are rebuilding uses a ring of 5/16" copper wire, 26" in diameter. It's just inside of the dome cover studs. I can't tell from the drawing how the ends are connected, but silver solder would probably work. Operating pressure is 225 psi.
BClemens
Re: Steam dome seal
Post by BClemens »
There is always High Temp Silicone Gasket Maker from Permatex..... it's not high tech but it works - especially with such a small deviation in gap. But I personally would go with the annealed copper ring (McMaster Carr) or welded wire (home tig job) - maybe backed up with the HT silicone for resilience during heat transients. The copper would have to be squashed to its hardened state or re-torqued a time or two until it wouldn't expand with the heat and become loose when it cools down. We (at Jlab) use copper gaskets on 'knife edged' flanges on vacuum vessels (intergalactic vacuum (E-12))
BC
Re: Steam dome seal
Previous two comments are useful.
To seal the steam dome lid on full sized steamers (180 - 200 psi operating pressure) we also (ref. Dick Morris) used 3/8" copper wire "H" shaped (actually a piece of trolly wire, because we had it available in quantity), silver brazed together at the ends. Initial tightening of the freshly annealed copper made an excellent gasket that sealed properly until the next year's maintenance cycle required removal of the lid. No re-torquing of bolts required.
But I'm pleased to read that "apm" seems to have resolved his issue with the steam dome seal.
10 Wheeler Rob
Re: Steam dome seal
Post by 10 Wheeler Rob »
If the dome surface is flat. I would put use 1/32 or 1/16" flat commercial steam rated gasket with the gasket or rtv gasket compound on the non flat boiler surface only. This would allow dome removal since the gasket is glued just on one side.
Rob
Chris Hollands
Re: Steam dome seal
Post by Chris Hollands »
Not sure what the top dome plate is , I machined o ring grooves in my dome covers , you could machine the groove slightly under full depth by 10 - 20 thou and that would give extra squeeze on the o ring and seal quite well with the pressure we run at , worked fine on my boiler at 300 psi test pressure .
jlakes85
Re: Steam dome seal
Post by jlakes85 »
I got a corrugated copper flange gasket installed and am now trying to get it properly seated. Is the objective to completely crush the ripples or is there something else?
