Page 5 of 6
Re: Blower
Posted: Fri Mar 30, 2018 8:04 am
by Fred_V
maybe it's higher RPM than mine.
Re: Blower
Posted: Fri Mar 30, 2018 9:05 am
by Bill Shields
They have 5 or six varieties all appear the same to a picture.
Re: Blower
Posted: Fri Mar 30, 2018 3:45 pm
by FRED DADDI
Bill Shields wrote:Fred:
If you need a better picture, I can do that. If you want to SEE IT I will be at PLS boiler test day end of April.
I can do dimensioned drawings if you want...but I need to know stack info....
No need for a drawing . Not impressed with the blower may het one like i had for redundancy.
Sent from my iPhone using Tapatalk
Re: Blower
Posted: Tue Jun 12, 2018 8:38 pm
by FRED DADDI
Ya know I cant really find a blower and am going to take up where I left off. Going to try one if the angled pipe adapters earlier in the thread. Bill what do you have? Maybe snap a picture?
Re: Blower
Posted: Tue Jun 12, 2018 8:59 pm
by Bill Shields
I have one of the grainger blower units described. I am away from home for a week and cannot take a picture right now but will do so this weekend.
Theae blowers move plenty of air. Two of them drive tbe coal furnace I use to heat my house. Tim just bought one for out Tom Thumb project and it does just fine.
Re: Blower
Posted: Wed Jun 13, 2018 7:18 am
by Fred_V
This is a nice size unit.
Dayton blower 1TDP7
tons of them on ebay. 146 CFM
Re: Blower
Posted: Wed Jun 13, 2018 7:23 am
by FRED DADDI
I have a 1TDN 2 from grainger
Re: Blower
Posted: Thu Jun 21, 2018 10:33 am
by Fender
Fred_V wrote: ↑Sun Nov 12, 2017 8:55 am
here is another way of doing it that works well too but more bulky. This design doesn't heat up or soot up the fan.
Fred,
With this type blower, how far does the smaller pipe, coming in from the side, extend up inside the larger pipe?
Re: Blower
Posted: Fri Jun 22, 2018 8:13 am
by Fred_V
Fender wrote: ↑Thu Jun 21, 2018 10:33 am
Fred,
On mine it doesn't stick inside at all; just grafted onto the side of the big pipe.
Re: Blower
Posted: Sun Jun 24, 2018 6:07 pm
by Fender
One thing not really discussed in this thread is the difference between propane and coal firing. With propane, not much draft is needed, just enough to clear the combustion gases from the firebox. On a large coal- burner, a lot of draft is needed to get a vigorous fire going to raise steam. I believe the smaller blowers may be inadequate for a large coal-burner.
Re: Blower
Posted: Tue Jun 26, 2018 11:57 am
by Bill Shields
as I mentioned (sorry I was not clear on this)…
the blower that I use on my locos (which are both propane and coal), I also use on my home furnace, which basically has an 8" x 10" grate covered in anthracite coal...and it makes plenty of blow to make things go...
now maybe PUSHING air vs. PULLING air may make a significant difference...
Re: Blower
Posted: Tue Jun 26, 2018 11:23 pm
by NP317
Bill Shields wrote: ↑Tue Jun 26, 2018 11:57 am
So that means you actually have a Sucker and not a Blower??
