mosely regulator adjustment
Bob Chamberlain
Post by Bob Chamberlain » Thu May 31, 2018 12:38 pm
I tested the output of my generator (MO-6) and it is producing about 12 to 14 volts AC power the regulator is plumbed in but not adjusted do I simply turn down the bonnet cap screw and adjust down to what voltage 3 volts 6 volts would like to run a small bulb behind the water glass. for night runs any suggestions thanks.
Will's 2882
Re: mosely regulator adjustment
Post by Will's 2882 » Thu May 31, 2018 1:07 pm
As I recall, you would low the pressure by turning the regulator CCW to slow the speed down. Start by testing as you watch the voltage, if it is going down then you going the right way.
Post by Bill Shields » Sun Jun 03, 2018 11:43 am
if you don't have a Zener diode I the circuit...you might consider it -> to keep from over-volting the bulb should the pressure(s) get out of control
