Best way to pin Stephenson eccentrics
I've finally accepted the fact that the eccentrics will keep slipping until I pin them to the crank shaft. Is a roll pin sufficient to keep everything in place?
-jlakes85
-jlakes85
Re: Best way to pin Stephenson eccentrics
Tapered pins are far superior to roll pins.
I learned from Fred_V a long time ago a really, really good way to do it. Once you have them set, use a drill through the eccentric to put a V dimple into the axle and then put a pointed set screw in backed up by a flat set screw. I did this on my Allen mogul and they have not moved whatsoever in 6+ years of running.
Once I had the valve gear set correctly, I drilled two dimples into the axle, at 90degrees from each other , thru all the eccentrics, and used a pointed setscrew to secure them....in 25 years, they have never slipped
I used the dual set screw technique described by John S.
No slipping in 15 years of service, so far.
I'm always a bit leary of pins through shafts. It's too easy to take too much strength away drilling through, and if the pin is small enough to not impact the shaft strength it's too small to do any good. Serious connections are keys and the dimple. The set screw lock screw, which I first saw in a Bridgeport head, works extremely well.
Pete
Pete
Just tryin'
Hi All,
Thanks for the responses. I'm leaning towards the dimple and two setscrew method. This is on a Shay loco, so I have better access than usual. I already have one setscrew per eccentric. I'm guessing I drill a new hole with a marked drill bit, tap using a spiral point to get rid of the chips and then use the two set screws? My biggest concern is losing the sweet spot while I drill the additional holes.
-jlakes85
-jlakes85
Yes: Use the first set screw to hold position while you drill, tap, dimple, and insert the second set of set screws.
Then remove the first set screw and repeat dimple operation +.
Drink a beer.
Better and easier method (requires pre-planning...):
Pre-drill and tap the eccentrics for two set screws, and THEN install and adjust position before securing in place.
Drink a beer.
The eccentrics on my shay are done with dog point set screws set into dimples with flat set screws behind and haven’t moved a bit with it on steam. One eccentric strap started to work loose but the eccentric itself it tight.
-Tristan
Projects
Projects
