Pump
hoppercar
Re: Pump
Post by hoppercar »
Guess I am not familiar with these pumps, I only know they look good, like a Worthington pump...why are the not reliable ?
Re: Pump
Post by Bill Shields »
Too mamy fiddly little parts inside. I have seem maybe 5 of them and none ran more tham a few monrhs.
PRR5406
Re: Pump
Post by PRR5406 »
Bill: How complex are the interior mechanisms?
Re: Pump
Very complex valving inside.
They typically have a vertical trigger rod inside the main piston shaft, that operates a slide valve for the horizontal shuttle valve, that operates the steam pistons.
All various forms of "control amplifier.", with many options to not work as intended, in miniature.
hoppercar
Re: Pump
Post by hoppercar »
Hmm....I didn't know they were so finicky....I've built several of the little engines single cylinder and twin cylinder pumps over the years, there pretty reliable, and work fairly well....guess I'll stick with one's of those, since you probably can't get the moes pumps anyway.....
Rayerroad
Re: Pump
Post by Rayerroad »
If your looking for a 1 1/2” reliable steam pump
Soler II double acting pumps are a great investment
I still have 3 left. Over 350 of them out there in service
See Soler II pumps under marketplace
Re: Pump
The Soler and / or Keim pumps, based on Bill van Brocklin's duplex (twin cylinder) design are very reliable.
If you want plans to build your own from these designs, they are readily available.
Berkman
Re: Pump
Post by Berkman »
I do not think the moes pumps are actually compound
Re: Pump
from what I have seen they may well be...but I have never had the guts to take one apart
Erie2936
Re: Pump
Post by Erie2936 »
Just to clarify a couple points, water pumps are never set up as compound. Water is an incompressible fluid and cannot be compressed a second time like an air compressor.
My two cylinder water pump is not based upon the Van Brocklin design. My pump contains the valve mechanism internally. The Van Brocklin and Solar pumps have external linkages that drive the valves. I'm not saying there is anything wrong with that design.
Both Van Brocklin and Solar work well when maintained.
Thanks,
Brian Keim
Keim Steam Pump
Extreme Steam
Brian Keim
Re: Pump
Giggle....incompressible water???? must be an old-fashioned idea....
I have only seen the Moes' pumps connected for air service
DianneB
Re: Pump
Post by DianneB »
Bill Shields wrote: Wed Nov 07, 2018 10:33 am Giggle....incompressible water???? must be an old-fashioned idea....
Are you out-of-date Bill? ROFL!
