Little Engines American Boiler
Fred_V
Re: Little Engines American Boiler
Post by Fred_V » Fri May 03, 2019 8:02 am
I hope he turns off the helmet cam when he goes to the bathroom!!
Fred V
Pensacola, Fl.
Pipescs
Post by Pipescs » Fri May 03, 2019 8:32 pm
A little history on LE back when Larry Kombrink built the one I have.
The boiler listed is the one in my American. It was fabricated using various castings and a five inch tube for the forward part of the boiler.
Cost for complete parts kit was $178.20 with an extra $45.25 if you needed LE to machine the parts. The catalog states that they would provide a completed boiler but it would require you to write them for a quote.
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
jessebanning
Post by jessebanning » Mon May 06, 2019 12:03 pm
Charlie, my American weighs in at 150 LBS. When finished, I expect around 155 lbs ish. I do not have the stock built up frame. The water jet frames are heavier, boiler is heavier, cab floor if heavy, smokebox, (mine is fabricated, the new castings are in cast iron, NOT aluminum) domes etc. I increased the steam supply lines to .3125" instead of .250". The grades at the Las Vegas/Boulder City Track range from 2.5 - 3.5. I do not recall what they are at Riverside Live Steamers. I also lowered the petticoat and exhaust which helps the draft and makes a clean smokebox.
I am doing away with all the aluminum parts and only using cast iron or brass. The new pilots are in iron and weigh more than the aluminum.
www.banninglocomotiveworks.com
www.littleengines.com
Fender
Post by Fender » Mon May 06, 2019 4:19 pm
Pipescs wrote:
Thu May 02, 2019 6:08 pm
Out of curiosity, do you know the year that Tom's Dad built the American?
Tom says the engine was originally built in 1964. The replacement boiler was made in 1983. The second repacement boiler is being completed in 2019. We won’t talk about when it was started. 🙂
Dan Watson
hoppercar
Post by hoppercar » Mon Jul 08, 2019 12:48 pm
nice..tig, welding is the only way to go....no slag, no porosity, ....
