check valve
check valve
Good evening to all, I am looking for a print for a two to one check valve I.E. two pipes in to one pipe out.I need it in 3/4" scale,for my 4-8-4 northern in 3/4 scale.Any help would be great,I have looked on many sites with no luck.
Re: check valve
Do you need a check and shutoff for each pipe and both output into one, or can you just combine both inlets into one check and shutoff with one pipe out? Where would this valve sit - side of boiler or top delivery? What size inlet pipes? I'd guess 3/16" OD for 3/4 scale.
Re: check valve
Have shutoff for each,need combine both into one check with one out am using 1/4 copper as inlet and outlet as I have about 30 feet of 1/4 I got for free.
Re: check valve
sorry had power go before I could say on side of boiler,we are having high wind here in Cleveland.
Re: check valve
two check balls, two inlets - one outlet?
Re: check valve
Hello squandt,
Please have a look on my topic Class A at Build Log, page 9:
viewtopic.php?f=45&t=103319&start=72
Maybe this would be helpful?
Asteamhead
Asteamhead
