Steam Locomotive model drawings
LVRR2095
Re: Steam Locomotive model drawings
Post by LVRR2095 » Fri Jan 10, 2020 4:36 pm
Hi Dick....that link works a treat!
Thanks, Keith
Dick_Morris
Post by Dick_Morris » Fri Jan 10, 2020 5:26 pm
There was a construction article of the 1" scale Atlantic designed by Lester Friend in the Miniature Locomotive starting May-June 1952
Beginner's Locomotive, 3/4" scale 0-4-0, Cliff Brackstaffe, construction article in Miniature Locomotive Sep-Oct 1952. Castings were available from the Miniature Locomotive Company in 1954.
3/4" B&O switcher by H.J. Coventry. Construction article in Miniature Locomotive starting Mar-Apr 1954. Continued in north American Live Steamer, Mar 1956 (only for one issue?).
Miniature Locomotive ceased publication with the Nov-Dec 1954 issue, so some or all of the series remained unfinished.
Harlock
Post by Harlock » Sat Jan 11, 2020 2:38 am
The list is starting to shape up nicely! A lot of stuff I forgot think of but should have!
Followup to my earlier comment on the RMI locomotives - I think only the originally Sweet Creek is Keith Watson's design, the others are derivatives dreamed up by RMI. I will check.
As for certain entities threatening you with legal action, you are entirely within your rights to make a LIST of locomotives they offer / have offered. Facts can't be copyrighted.
LIALLEGHENY
Post by LIALLEGHENY » Sun Jan 12, 2020 3:02 am
3" Hudson, drawings by Seymour Johnson.
Nyle
Dick_Morris
Post by Dick_Morris » Sun Jan 12, 2020 6:55 am
1-1/2" O-4-0 Reading A5a Camelback, 7x gauge, Elmer Nuskey, Jr.
1-1/2" 0-4-0, L'il Lima, 7.25 gauge, 2-1/2(?) scale, Wato Locomotive Works
Lima Mogul, 2-6-0, 7.25 gauge, 2-1/2" scale, Wato Engineering
NYC(?) 2-4-0, 7.25 gauge, designer unknown,
Light Mogul, 7-1/2 gauge, 1-1/2 scale, Paul F. Brien
2-6-2, 2" scale, 7-1/2 gauge, Joe G. Whitaker
Denver and Rio Grande c-19 2-8-0, 2-1/2" scale, 7X gauge, Milner Engineering (later sold by C.A. Street and Sons and then by Power Model Supply)
Walt Disney Lillybelle drawings are available from California State Railroad Museum
The full drawing set for the replicas of the Jupiter and UP 119 are available on the Intenet. Although full scale, much use was made of fabrications and they lend themselves to scaling down for a live steam model.
Kevin S
Post by Kevin S » Sun Jan 12, 2020 12:59 pm
The Milner 2-8-0 is avalible from A.J. Reeves currently.
MsChrissi
Post by MsChrissi » Sun Jan 12, 2020 1:38 pm
M-21 Mogul?
Dick_Morris
Post by Dick_Morris » Sun Jan 12, 2020 7:09 pm
M-21 Mogul?
Generic.
Pontiacguy1
Post by Pontiacguy1 » Mon Jan 13, 2020 8:39 am
That Light mogul that was drawn by Paul Brien of Nashville is actually a re-drawing of the Pershing G. Scott Mogul. It beefed up a few things, gave a huge amount of detals, and used larger rods, but the locomotive is the 'Scotty Mogul'.
Also add to the list the Miller Backyard Railroad 4-4-0, which used piston valves and 100% cutoff, with a plunger in the middle which changed it from inside steam to outside steam for reversing. Paul Brien built one of those 4-4-0s, heavily modified to make it work and track better. He then designed a 4-6-0 using those castings, which he called the LRR ten-wheeler. Unfortunately the cylinder casting (1 piece casting) which was used is no longer available.
Steven E. Kuhn
Post by Steven E. Kuhn » Mon Jan 13, 2020 6:09 pm
Very interesting. Thank you for doing that.
Steve Kuhn
Wayne Davis
Post by Wayne Davis » Mon Jan 13, 2020 8:51 pm
I built a Scotty Mogul with valve gear drawing from Paul Brian's 260. The drawings Scotty sold were from Bill Hall that he drew up from Carl Purinton's Mogul. Paul made improvements to Carl's engine and it is a sweet running engine.
Wayne
Sandiapaul
Post by Sandiapaul » Mon Jan 13, 2020 9:12 pm
