Spring Steel
jeffsmith
Spring Steel
Post by jeffsmith » Wed Jan 22, 2020 7:12 pm
I am making some leaf springs for tender trucks. I am using blued #1095 spring steel. What is the best way to bend a curve into the leaves so they will take a set. Any suggestions out there. Thanks
Greg_Lewis
Re: Spring Steel
Post by Greg_Lewis » Wed Jan 22, 2020 7:42 pm
I just bent mine with my fingers over a piece of pipe of some eyeballed diameter. Bend before drilling any holes.
Fender
Re: Spring Steel
Post by Fender » Wed Jan 22, 2020 9:00 pm
Try hammering them against a steel pipe with a rubber hammer. This makes a smooth curve, and prevents a kink.
Dan Watson
Dick_Morris
Re: Spring Steel
Post by Dick_Morris » Wed Jan 22, 2020 9:25 pm
I made a die from a piece of pipe with a spigot welded on and some 2x4 with a radius cut into it, used on an arbor press. Some experimentation is needed to get the radius right. Some of what I got came off the roll at about the right radius.
Something I learned while acquiring spring material, some of what I bought is rolled to the correct width with nicely rounded edges, some other is sheared to width and has a somewhat rough edge.
hoppercar
Re: Spring Steel
Post by hoppercar » Thu Jan 23, 2020 8:03 am
I rolled mine thru a sheet metal roller, made easy work of it
Marty_Knox
Re: Spring Steel
Post by Marty_Knox » Thu Jan 23, 2020 11:32 am
Just make sure to run it through both ways so you don't end up with a flat spot at one end.
Steve Goodbody
Re: Spring Steel
Post by Steve Goodbody » Thu Jan 23, 2020 5:06 pm
Hi Jeff,
With my loco springs (1/16" x 1") I bent the steel when in unhardened / un-tempered condition using a simple curved hardwood press tool (a male and female former) squeezed together in the bench vice. I pressed long lengths of steel a short section at a time to create a continuous curve, then cut the springs to length afterwards avoiding any flat sections. Then I hardened the leaves - cherry red and oil quench - followed by tempering in molten lead.
I tweaked the bottom leaves to a slightly tighter radius in order to pre-load the pack and keep everything tightly together upon assembly.
Best regards
KarlKobel
Re: Spring Steel
Post by KarlKobel » Thu Jan 23, 2020 6:20 pm
Hoppercar didn't say whether he rolled them individually or the whole length before they were cut like I did mine.
That way I could get the 'correct' radius for all of the pieces.
I set up a stop in the shear to make each length in turn.
My tender has 12 sets of spring assemblies per truck.
Sorry, no pictures of the spring construction.
http://www.karlkobel.com/Tender/TenderTrucks/index.html
Karl
