Calling Marty Knox
Calling Marty Knox
Marty,
Attached is a photo of my buddy's Tom Thumb boiler, you'll notice the large bulge on the water jacket; our question is, can this section be cut out and patched, or should this boiler be heading for the scrap pile? This engine was probably running at NJLS when you were there, after my buddy bought it, he was cleaning and inspecting it and found the problem with the boiler. We'd like your opinion, thanks.
John
John
Re: Calling Marty Knox
First, is this copper, or steel? It's hard to tell from the picture.
Is there any way to look inside?
It's a copper boiler Marty, I should have said that in the original post. Yes there are some potential access points. One of the guys at the club has an inspection scope, I think we'd be able to borrow it and fish it in to look around a little, what would we be looking for?
John
John
A buildup of scale or some other reason for the bulge. I suspect someone may have got carried away with a hydro.
easier to build a new boiler than fix that..
My thinking is this occurred while it was having extreme localized overheating, which could have been caused by several things, the obvious reasons (low water, too much fire, etc), and as Marty mentions a buildup of scale which prevented water from reaching the area. I doubt it was an over-zealous test as I would have expected a burst (split) in a flue, or at a joint or seam, before a tube wall deformed that much.
GWRdriver
Nashville TN
Nashville TN
My reaction on inspecting the picture was:
Scale buildup on the water side. Under pressure and heat it bulged.
Time to replace the boiler, if it was mine.
find out when you cut it apart....
Yeah, we were pretty sure the boiler was unsalvagable. Not that I'm a boiler maker, but I thought it was odd that there were no stay bolts in the water jacket area. Thanks for the replys. John
There don't need to be any stays in a round surface, typically...the thickness of the round surface has to be able to take the hoop stress, but there is no need for stays, which renders "Marine type" fireboxes far easier to make...
That being said, I would recommend cutting apart this boiler to figure out what went wrong. I suspect that there is scaling in between the two surfaces.
James
James
stays in the water jacket are not needed (in any of the Tom Thumb boilers I have built).
Yes, the wrapper does have a calculable crush pressure, but it is well over 150 PSI...
put the boiler in a band saw and saw it in half
You never know what you will find...
