Most cost efficient way to get steel tire blanks?
LIALLEGHENY
Re: Most cost efficient way to get steel tire blanks?
Post by LIALLEGHENY » Mon Feb 24, 2020 2:14 am
Check out Specialty Pipe and Tube in Ohio /Texas. Another possible is EMJ Metals.
The majority of the smaller online suppliers, Speedy Metals, Metals depot, Online metals, etc, charge a premium . They'll sell you any cut size you want, and they include the cut cost in the price, whereas many large suppliers will only sell full lengths, and charge for cutting.
Nyle
Post by Harold_V » Mon Feb 24, 2020 2:50 am
Fender wrote:
Sun Feb 23, 2020 5:45 pm
Harold, who offers this? Is it available in small quantities? The other challenge is getting tubing in the right diameter, with sufficient wall thickness.
I posted on the strength of the EMJ handbook, which I use as my bible for materials. You can find them online to verify that they actually have the material. (Earl M. Jorgensen)
I used to use them as my source for alloys when I was actively machining. They had a huge inventory and prices were highly competitive. I can't speak for them as of today, as that was many years ago and they may have undergone some less than good changes.
Another good source, at least back then, was Marmon Keystone. They are likely found online, too.
LIALLEGHENY
Post by LIALLEGHENY » Mon Feb 24, 2020 4:41 am
Harold,
I still buy from EMJ. They still have a huge inventory, and everything can be accessed online if you register. Pricing is competitive, but that depends o what your looking for. Pennsylvania steel is another supplier I deal with frequently.
Nyle
WJH
Post by WJH » Mon Feb 24, 2020 7:36 am
I'll keep you in mind, those are much bigger than I need as my wheels need to be scaled 33" but price wise they may win out. I'm over in South Korea at the moment working.
cbrew
Post by cbrew » Mon Feb 24, 2020 8:14 am
I had good success using Speedymetals, not the cheapest route but always on task.
https://www.speedymetals.com/c-8242-round-tube.aspx
rkcarguy
Post by rkcarguy » Mon Feb 24, 2020 12:33 pm
We also buy our alloys from EMJ, nothing wrong with them if you want to go with 4140 or another hardening steel. I agree with another poster though and think that a hardened wheel would suffer from low traction.
cbrew
Post by cbrew » Mon Feb 24, 2020 1:25 pm
a little tool chatter does not hurt either
you know you worked the locomotive like a mule when you have to brush off the alum dust off of frame :shock: :lol: :wink: :roll:
Fender
Post by Fender » Mon Feb 24, 2020 5:17 pm
Although, in some cases a lower coefficient of friction can be an advantage. I used 4140 pre-hardened for engine truck wheels, where you want a lower amount of friction for going around curves and not having the flanges climb the rail head.
cbrew
Post by cbrew » Mon Feb 24, 2020 6:34 pm
i have found when a flange is climbing the rail head the profile is wrong.
Fender
Post by Fender » Mon Feb 24, 2020 7:03 pm
Chris,
My point was that traction is only desirable for driving wheels. Harder wheels for cars and engine trucks should result in lower rolling resistance.
LIALLEGHENY
Post by LIALLEGHENY » Mon Feb 24, 2020 8:15 pm
Does anyone know what hardness wheels are on full size locomotives? and what type of steel?
jcbrock
Post by jcbrock » Mon Feb 24, 2020 10:37 pm
Pulling out the trusty 1930 Loco Cyc lists the ARA Recommended Practice, 1920 revision.
Carbon Per Cent
Passenger 0.50 to 0.70
Freight 0.60 to 0.80
Switching 0.70 to 0.85
Remaining elements
Manganese 0.50 to 0.75
Phosphorus not over 0.05
Sulphur not over 0.05
Silicon 0.15 to 0.35
So a high carbon steel in 1920.
Edit, this is the makeup of the tires, not the centers.
John Brock
