Brass strapping material
I can't seem to locate a vendor of brass strap..5/8" wide, 025" - .032 thick, 30" long.
Any help?
Thank you
Tom
Any help?
Thank you
Tom
Re: Brass strapping material
Brass is easily sheared...McMaster-Carr - raw materials - metals - brass/copper then make your choice.
HTH, bc
HTH, bc
Thank you.
i scribe it and cut with snips.....
This is the reply from McMaster-Carr they don't have anything close.
But thanks for the tip.
Tom
Hi Tom,
We have brass strips in those thicknesses, but not the exact dimensions. I've linked our closest options here.
Mandy
Tom
Hi Tom,
Mandy
Go to https://classic.onlinemetals.com They will cut it to the size you need.
Mr.Ron from South Mississippi
Sorry, looks like you needed the precise size. Usually a given thickness sheet is ordered and the exact width you need would be sheared or snipped from it. These suppliers can provide the shearing service but will charge exorbitant prices for the over and above their normal stock sizes. You will pay for a sheet anyhow...
bc
Sorry, I have surfed for hours........no one offered "cut to size" Most model material starts and ends at 12".....
Good thing I have a shier! I just ordered 1" x .031 x 36" for dirt, I get 5 strips delivered for under $40..Not bad.
Thicker and wider than I wanted...but I'll shier it..
Now you're talking! Good going - shear it yourself. Way to go!
bc
bc
I found some thick brass, surplus door kick panels and cut them into strips on my bandsaw.
Here’s a link to a video discussing them: https://youtu.be/cvEAuYiQZjU
Hope that helps!
Bill C.
Hope that helps!
Bill C.
