Ash Pan Latch Ideas?
The ash pan drop-down doors on my Allen Mogul were completely unworkable. I am converting the rear access to a slider, but I need an easy to use latch for this front access. It would nice to have something that trips easily with the poker, and then automatically re-latches when pushed back up. I'm sure that there a few ingenious designs out there, hoping for a share.
Thanks,
-Richard
Thanks,
-Richard
- SZuiderveen
Re: Ash Pan Latch Ideas?
I had swing bottoms. Many cuss words over years. Here is the new ash pan:
Steve-
Steve, the next time I lift to boiler I am absolutely 100% doing it the way you have shown. For now I need a retrofit for the front. I am doing a sliding arrangement like you show for the rear pan.
Thanks!
Thanks!
The slide is a great construct. Just be careful that it will still slide:
When full of ashes
When hot
After it has been thumped a few 100 times by the 'ash pan poker.
When full of ashes
When hot
Put a slight bend 1/2" or so from the back end.
Enough that you almost have to force the last 1/2" in.
Friction will keep it in place without a latch.
Bill, good point. I have a gap on the slides, we shall see.
Marty... I like the idea of using friction. I'm not quite following the geometry you describe. Could you provide some more insight?
Thanks!
Thanks!
Assuming it is steel, a magnet on the slide mounted so that it contacts the face of the pan that faces rearwards will hold it closed.
Or put some brackets on the front to hold the magnet and a place for it to clamp to.
Love the idea of the remote release. However, MAGNETS. I'm on it Steve. Perfect solution. Thanks!
Here is a sketch of what I'm suggesting.
I get it now. Thanks for taking the time to post that Marty.
- PeterCraymer
I formed the slides on mine during construction as opposed to adding angle like Marty suggests, but do you have room to get in there with a couple of rivets or screws & nuts to add the slides to the front hopper as well using some small angle? Once you can open both front and rear hopper with one movement (mine has a hole to be able to grab it with the poker and a piece of flat bar welded to the slide gate as as stop - with a little bend for some friction) you wont be the same! I cant imagine trying to get a rod across and little cotterpins or whatever while the engine is hot. I will also recommend that if/hen you get the chance that you make them as wide as you can. Helps extend that run time before needing to make a trip to the ash pan.
