Anthony,
Not familiar with your foundry's process, but you did say
...go back to castings for the bodies given recent success with my foundry.
indicating that you had a process that worked once upon a time. Question is, what changed? Just as a starting point, you could look at the process from a high level and ask "what's different". This type of "fishbone" or "cause and effect diagram" might be helpful.
On the other hand, if you haven't used this foundry before
...this is the only time I've ever had anything cast solid so I have no context for if this is to be expected or not. It may be that these are too large to cast solid for this specific foundry's process
then their process may be incompatible (for whatever reason), with your particular parts. And it may not be economical to re-engineer their process, and they may not want to change.
Best regards,
SteveR
