Buckeye update
- Pennsy fan
Buckeye update
Well after making 140 parts just for the working clasp brakes and getting the rest of 40 trucks parts done. They are done, now to the frame.
- Attachments
- buckeye_555-resized.jpg (24.48 KiB) Viewed 5416 times
- buckeye1_167-resized.jpg (31.41 KiB) Viewed 5416 times
- table_703-resized.jpg (42.95 KiB) Viewed 5415 times
- Pennsy fan
trucks
Hi Robert,
They are mountain cars.
As for the weight the tank should hold over 30 gal of water, I think. And I am
over 230 + coal then the tender itself. So yes I hope the brakes do well.
We have good grades here at the L.A. club and it's nice to have good control
of the train.
of the train.
Responce, the 1st: Nice looking trucks! They look like you've spent a good deal of time on them. : ]
Responce, the 2nd: I'm glad you posted those photos... It's the first time I've had a chance to see how these style trucks function from the inside. : ] One of these days I might have to try and do them in 1:29th...
Trot, the impressed, fox...
- Pennsy fan
trucks
Thanks Fox, yes there is a ton of time in these. Around 40 hrs.
If you want try your hand doing a set check out one of the locomotive cyclopedias that have the trucks in prints. I have a 1941, 1950-52. I don't know what one has them but I know I have seen them.
I got a set of prints from a friend of mine so this what I used, also prints that came with mountian car trucks.
David.
David.
If I ever do it I suspect I'll be making simply functional trucks that don't look much like the originals. I know of no castings in my scale for such complex trucks... not even dummies! I know I could get them made for the right amount of money... but that's more money than I'll likely be willing to spend. } ; ] Who knows? We're talking years into the future here anyway. : )
Trot, the hot-air-filled, fox...
- Pennsy fan
trucks
I used MCC because the trucks I needed for the tender has the timken bearing covers. As for truck castings I got got them raw, but the wheels came finished. Also I made the axels. As for others there is the set for NKP birk from real trains, very nice but NOT cheap. These have lost wax parts
and are scale. $3200 a pair. These have roller bearings but are the plain bearing style caps so I couldn't use them.
- Location: Ohio ( Just nawth of the Mason &Dixon______ )
Re: Buckeye Update
Dave,
I am curious, does anyone supply a four axle Buckeye truck? Say similar to the ones tucked under a Chesapeake and Ohio H-8 Allegheny?
Andy
Andy
The greatest gift that a man can posess is the determination not be hurried.... Thoreau
