Challenger tender photos
- Chris Hollands
challenger Photos
Sorry to disappoint oh Canada but Im Australian .
The nickel plating kit was the normal anode type and if any body is thinking of using such a kit go for it ,dont do what I did and research it to death and buy books and all sorts of other info BECAUSE YOU DID NOT HAVE CONFIDENCE in your ability and it was some sort of black magic.
(I want to do photo etching that scares me ,what I really want to learn is lost wax casting Help please)
Remember number one when using these kits it has to be spotlessly clean , find a neutral type degreaser that leaves no residue if that makes sence and only do small quantities at a time
Re: challenger Photos
When I left the shop, having been totally burned out on machining, my next endeavor was refining precious metals, which I pursued until I retired, just before I turned 55.Chris Hollands wrote:what I really want to learn is lost wax casting Help please)
I worked closely with manufacturing jewelers, who use that process daily. I suggest you find someone in your area that is involved with making custom jewelry and ask for his/her input. It is common, at least here in the States, for larger jewelry stores to have a benchman in the back room, who routinely does repairs, and often manufacturing of custom jewelry.
Once you get familiar with the process, you'll find it's very easy to do, but there are certain requirements that should be met.
- Krank Turner
Indeed high grade!
The words have been said, no need repeating them. However; if I wore a hat I would remove it in the presense of that piece of art, and my "hat" is off to you also.
Exceedingly well done.
Always stopping my train in a safe manner with good 'ol reliable NIKE brake shoes... size 12 basic black.
Krank Turner
Krank Turner
Re: Challenger tender photos
2000 parts.Chris Hollands wrote:The brakes and suspension are prototype with inexcess of 2000 individual components nuts bolts pins bushes etc.
How many drawings where there for the tender brake rigging alone for the full size locomotive?
- JBodenmann
Brake rigging can really add up. On the Nickel Plate Berkshire tender brake rigging there are 120 little #6-40 bolts in three different lengths that you get to make, and each one has a tiny hole in it that the tiny cotter pins fit through to hold the 120 castellated nuts that you get to make. This is just a small hand full of little bits for the brake rigging.
Get R' Done!
Jack
Get R' Done!
Jack
My point.
How many builders have access to prototype blueprints?
If I am going to go to all that work, I want it to be as close to prototype as I can get it.
Case in ponit.
I need a flatcar for a load of 6 tractors. I model the CNW, which had both 42-foot and 46-foot flatcars built in the 20s. Of the 5 groups built I was able to find the original drawings for one group of 42-foot flatcars. Most of the people I have talked to tell me I am crazy to spend that much time on a flatcar. But due to the fact that I will not be able to start on my big engine anytime soon I am focusing on something a little smaller to work on my detailing skills.
BTW does anyone know were I can purchase some 5/64” round head steel rivets?
Great work
Tim
Case in ponit.
Great work
Tim
Absolutely gorgeous workmanship.
Though for some of us machining rookies, photo's like these can be a double edged sword. On one hand they serve as great inspiration of what can be achieved in this scale and yet they can overwelm us by the sheer complexity of it all.
My hat's off to you "Master" builders.
Bobby
Bobby
- tsph6500
We won't hold that against you considering the decent quality of your work.Chris Hollands wrote:Sorry to disappoint oh Canada but I'm Australian.
Best regards,
Jim Leggett
Montreal Live Steamers
www.montreallivesteamers.org
A Founding Member of the Tinkerbell Scale Society - Northern Division
I'm an A.R.S.E. (Association of Railroad Steam Engineers)
Toad Swamp & Punk Hollow Railroad - Head Tycoon
The Juvenile Traction Company - CEO & Apprentice Machinist 3rd Class
White Mountain Central RR - Engineer & Fireman
Jim Leggett
