Olburner for small models
Asteamhead
Post by Asteamhead » Fri Aug 03, 2012 3:34 pm
Some photos of the 7 1/4 " oil burner of type WDH
Asteamhead
makinsmoke
Re: Olburner for small models
Post by makinsmoke » Fri Aug 03, 2012 4:16 pm
I tell you what, folks.
Say what you want, the Germans sure build some amazing stuff.
I keep reminding myself that's a burner in what scale?
Love the gears!
B
Loco112
Post by Loco112 » Fri Aug 03, 2012 4:44 pm
How large is the burner in; L, H, W?
Narrow Gauge (Information) Exchange dot Org forum
My Projects:
Davenport 30 ton diesel (SV#101 / D&RGW#50)
C&S 1908 steel & 1905 wood: box, stock, flat, gon
D&RGW wooden freight cars, long & short cabeese
EBT 2-bay hoppers, Conoco #44 tank
DV (K&J) hopper
8"n3 - 3-footers, 8" scale, 24" gauge
Asteamhead
Post by Asteamhead » Fri Aug 03, 2012 5:20 pm
The burner for 7 1/4 " measures about 2 x 2 x 1 inches (L x W x H). The one used for my class 44 1167 is a bit smaller. It's fixed to the frame / front of the ashpan with just one srew from the side for easy access.
The ring at the oil nozzle in combination with the small pan beneeth is to avoid any spilling of fuel to the ground. Steam is throttled by an external valve while oil is adjusted directly at the nozzle. Power / oil may be throttled smokless from about 2 pounds to 10 pouns per our.
Thank you for your interest!
Asteamhead
Fred_V
Post by Fred_V » Fri Aug 03, 2012 5:22 pm
what does the gear do? some pic of it disassembled would be great.
Fred V
Pensacola, Fl.
Asteamhead
Post by Asteamhead » Fri Aug 03, 2012 5:53 pm
To Fred_V
The gear provides a wider angle (about 120 %) for the throttle lever in the cab. It turns the outside oil nozzle by means of a fine thread of 12x1 mm.
May the drawings* will explain a little better the function of th inside steam nozzle of diameter 0.5 to 0.7 mm, surrounded by the wider and adjustable oil nozzle of 1.6 to 1.8 mm. Diameters depend on size, intended preasure of the (superheated) steam and type of oil. The burner is lifting the oil (diesel, petroleum, light oil) by generating a light vacuum. Bio-diesel will be atomazed too, but needs to be preheated.
* Have to convert the article from MS word first, sorry!
Just a photo showing the loco on an electrical brake board.
Asteamhead
Asteamhead
Post by Asteamhead » Fri Aug 03, 2012 6:29 pm
Oil burner, drawing 5 ", measures [ mm ]
Capacity 10 pounds light oil per hour (for about 100 pounds of steam per hour).
Steam demand 3 pounds per hour (6 bars, superheated
Asteamhead)
mjahn
Post by mjahn » Sat Aug 04, 2012 12:39 am
Very interesting! Definitely saving this thread in my locomotive's research folder. :)
Mattaniah Jahn
Matt Corps. Railsystems,
operating on the Manatee Central RR
http://www.flickr.com/photos/62441046@N06/sets/
