Valve gear type?
John_S
Valve gear type?
Post by John_S » Tue Feb 05, 2013 9:01 pm
I've started looking into what's next for me and going through lots of Rock Island photos and there's a couple 2-8-0s that interest me; however, I'm stumped as to what type of valve gear these have. Take a look at the cylinders and valves:
Fender
Re: Valve gear type?
Post by Fender » Tue Feb 05, 2013 9:25 pm
Most likely Stephenson valve gear. Piston valves are inside the frames.
Dan Watson
makinsmoke
Post by makinsmoke » Tue Feb 05, 2013 10:23 pm
Man, I bet it's really busy under there......
SoCalLiveSteamer#613
Post by SoCalLiveSteamer#613 » Tue Feb 05, 2013 10:24 pm
Many engines were built like this in the early years with the inside facing valves. Kinda throws the eyes off. Like everything else though they eventually pushed them back on top because it was a nightmare to work on! Some of the old Stevenson gear engines had compound cylinders as well. Occasionally you can see the extra piston housing in the cylinders of older engines but most of them were later converted back to conventional high pressure steam only. The SP mogul here in Lomita at the museum is like that.
Going in circles any day, anywhere as long as its on a steam engine!
Post by Bill Shields » Wed Feb 06, 2013 6:27 am
The compounds are called Vauclain Compounds..
Stephensons with piston valves were quite common for a few years until some guy from Belgium came up with a better idea :lol:
Some locos actually were rebuilt from slide valves to piston valves by replacing the cylinders on existing chassis and reusing as much as possible (like the valve gear). Jim Stuart told me of several B&M locos that had that 'conversion'.
The British did locos with valves inside the frames clear up to the bitter end.
After that, their loco designers went to work for the motocycle industry, which also came to a bitter end...
FLtenwheeler
Post by FLtenwheeler » Wed Feb 06, 2013 6:59 am
The Chicago & North Western 1385 at the Mid-Continent Railway Museum has this arraignment.
Tim
John_S
Post by John_S » Wed Feb 06, 2013 1:16 pm
Had a moment to dig through http://www.steamlocomotive.com and found these two consolidations.
They both had Stephenson valve gear and were built by Brooks 1917.
Working on the Stephenson on my Allen mogul was enough for me... don't really want to tackle that again, especially with the inboard valves!
Post by Bill Shields » Wed Feb 06, 2013 1:19 pm
Chicken....
If you build it correctly, you don't have to do anything to it (giggle)..... :lol:
Doug_Edwards
Post by Doug_Edwards » Wed Feb 06, 2013 2:44 pm
C'mon Bill, surely you know that Walchearts valve gear predated piston valve use on railroads by decades, not piston valves predating Walchearts! The SP/CP used a modified Walchearts gear in the early 1880's. and the Mason Bogies were built with it also before the turn of the century.
Bill Shields wrote: Some locos actually were rebuilt from slide valves to piston valves by replacing the cylinders on existing chassis and reusing as much as possible (like the valve gear). Jim Stuart told me of several B&M locos that had that 'conversion'.
The PRR D16sb 4-4-0 at the museum at Strasburg is one that the cylinders were replaced with piston valved cylinder castings. Apparently, the PRR was too cheap to spend to much money, as the new piston valved cylinders use outside admission valves. Looks like they didn't even change the valve gear!
Regards,
Doug
http://www.precisionlocomotivecastings.com/
Building a 70 ton Willamette in 1.6"
Building a 80 ton Climax in 1.6"
"Aim to improve!"
"Mine is not to question why, mine is just to tool and die"
Post by Bill Shields » Wed Feb 06, 2013 3:22 pm
predated - yes.
common usage in the USA....well, that is another story.
drgsw464
Post by drgsw464 » Thu Feb 07, 2013 4:06 pm
john_s
I'm work on Stevenson valve for the Alan models 2-8-0 you move the rocker arms forward one diver set and use a transmission rod
nickco201
Post by nickco201 » Thu Feb 07, 2013 11:46 pm
Many southern locomotives, a good example being many of their K series of 2-8-0s, were built with slide valves/Stephenson then converted to piston valves with new cylinders or universal steam chests. At the same time they received either Southern or walscheart valve gear.
Southern 630 and 722 followed this trend, they looked quite different new. Here is a builders photo of 642 http://southern.railfan.net/images/arch ... ou642.html
Here is a photo of it years later showing the universal steam chest application, valve gear change, and other modifications that the southern carried out on it. http://southern.railfan.net/images/arch ... ky746.html
- Andrew
