Mach3 and digitizing with 3d probe to create G code
This forum is dedicated to those Hobbyists Interested in CNC machining in their home shops. (Digital Read Outs are also topical, as is CAD/CAM as it relates to CNC)
JohnR
Post by JohnR » Wed Sep 02, 2020 2:33 pm
I wish to use the mach 3 digitizing wizard and a 3D probe to scan castings to make patterns.
After scanning I would like to import into my Cad Cam package and adjust to create a viabale
pattern on either the mill or router.
Anybody done anything like this .
I cannot find any information on the Mach wizard such as a manual or tutorials.
Any help would be greatly appreciated.
JohnR
ctwo
Re: Mach3 and digitizing with 3d probe to create G code
Post by ctwo » Thu Sep 03, 2020 10:31 am
I used the hoss blue screen package since he made probing macros, and a home made probe. If I recall, it generated a point map in stl format.
https://www.chaski.org/homemachinist/vi ... be#p371856
There is a zip download in the thread here: https://www.cnczone.com/forums/benchtop ... e-set.html
ctwo
Post by ctwo » Thu Sep 03, 2020 10:38 am
Or actually it might have been the big-tex probing screenset. That's what my screenset looks like. The site is gone but the screenset can be downloaded from here:
https://ngeneyes.com/domains/big-tex-tk/
You can see an image of it here: https://www.machsupport.com/downloads-u ... creensets/
Post by Bill Shields » Wed Oct 28, 2020 10:15 pm
It is not just the final surface but how you get there.
Where you are headed is truly an experience
JohnR
Post by JohnR » Fri Oct 30, 2020 7:07 am
Thanks again for the replys but I am still looking for help.
What I am looking for I a digitizing software for contour work that is applicable
to mach 3 platform.
It will be used to digitize molds used for thermoforming both male and female
cavities, also the occasional train part.
Thank you
John D.
Post by Bill Shields » Fri Oct 30, 2020 9:49 am
so you are looking for
something that will drive MACH 3 XY to create points using a 'rough boundary' of the surface and a touch probe
and / or
something that will take a point cloud and create a 3D surface from it that you can feed to a CAM system to create G-code to drive the cutting tool
JohnR
Post by JohnR » Fri Oct 30, 2020 10:45 am
Bill
A program that will create a point cloud for 3d surface that can be imported into
cad cam (probably Bob Cad) to create g code .
I will be using a ball style digitizing probe.
I have looked at Crafty Cnc which will do X and Y for perimeter but also need Z for contours.
Need to run on Mach platform.
Thank you
JohnD
Post by Bill Shields » Fri Oct 30, 2020 4:04 pm
did not know that BobCAD did point cloud sorting....guess i am a decade or 4 behind the times with their capabilities.
all things considered...it will probably be well worth your while to just take the part to someone with a laser scanner and be done with it.
