Stepper setup?
Stepper setup?
Hi I have just got my Mini CNC machine working now I need to setup the steppers sow the machine will cut to the dimension that the program calls for. How do I set this up without guessing? I'm using Mach1 CNC and bipolar steppers what other information do I need to now to make this work thanks
Re: Stepper setup?
Hi Rod;
Someplace in your software will be a place to set up the steppers max speeds, ramps speeds and so on. Look for a line than says "inches per step". May sound crude but I used a dial indicator and gage blocks to set inches per step via trial and error. Change the numbers and do a test run to see if the machine moves the exact distance. Change the number in small amounts untill it moves the distances desired.
Jim
Jim
www.outbackmachineshop.com
Re: Stepper setup?
Rod -
Jim said to use the inches per step parameter in your setup -
It may also be stated as steps per revolution.
If you know the steps per inch - then inches per step is 1/n where n is the steps per inch. Conversely if you know the inches per step, then 1/m gives you steps per inch - where m is the inches per step.
Example -
200 steps per in - 1/200 = .005 inches per step
.005 in/s - 1/.005 = 200 s/in
have fun with it.
Example -
have fun with it.
Dave
Smithy 3in1, Select Mill, Atlas 6" lathe
Re: Stepper setup?
Thanks for the help. My machine now jogs to the proper dimension but when I run a program the machine only moves about 25 percent of what it should sow I will have to find the settings for that. Dues anyone now what setting I would need to change thanks Rod MI
- Site Admin
Re: Stepper setup?
Rod, what/where did you find your problem?
I think I have it working now thanks
Re: Stepper setup?
I reset the encoders back to where they where originally if that fixed it I don't now! But I found out there whose sum wood or plastic from the factory that whose stalling the X stepper out. I would think that whose the problem Rod
