Hi Friends,
I am planning to do 3D CNC prototyping services using a small CNC milling with 4Axis attachment. Can any one suggest which is the cheap and good machine for cutting plastic, Al foam etc. I dont mind to buy DIY kits. Please help.
Kusuma
subhash@starhub.net.sg
Prototyping
- Mid Day Machining
Re: Prototyping
I would look at the Tormach. If you go with a DIY machine, you'll get exactly what you pay for.
You can buy good parts, or you can buy cheap parts, but you can't buy good cheap parts.
Re: Prototyping
The first thing you must consider is work envelope.
Shields' first law of CNC machine purchase is
"10 minutes after you purchase a machine that is more than large enough for the BIGGEST job you have ever done...a job TOO BIG for the machine comes in the front door."
Sometimes getting an older (larger) machine and fixing it makes more sense in the long run - but that is a decision only you can make, based on a lot of factors unknown to everyone else.
Just 'plan wisely', because sticking a 4th axis on the table of an already small machine can cause 'size problems'.
- Mid Day Machining
Re: Prototyping
Do you want a good machine or do you want a cheap machine? There is no such thing as a GOOD CHEAP MACHINE.
Re: Prototyping
Chuckle!
kusuma, who asked the question, did so on March 21, 2005, and has not returned to the board since.
I wonder if he ever found the machine he wanted?
Re: Prototyping
You could check out http://lobocnc.com. This is a lightweight hobby CNC machine I designed. It's an open-source, DIY project, with complete published parts lists and drawings. I'm selling some of the trickier parts (electronics, sheet metal structural parts) to simplify things, or you can make your own.
-Jeff
-Jeff
Re: Prototyping
With a time machine, no need for a CNC machine.
