Valve cover Badges
V8 BUG
Valve cover Badges
Post by V8 BUG »
Start with a Solidworks design
Program, load into mach3 and run.
Out of machine and final polish. (these are for my own car)
More projects to come.
Kevin
BUILDING IT IS MORE FUN THAN BUYING IT
V8 BUG
Re: Valve cover Badges
Post by V8 BUG »
This mornings work....still need to be painted. These will be going on a 1932 3 window coupe with an open engine bay.
dly31
Post by dly31 »
That is a great idea as well as great looking work! Thanks for sharing.
Don Young
oldvan
Post by oldvan »
Beautiful.
What are you using to get from SolidWorks to G-Code?
V8 BUG
Post by V8 BUG »
Old Van, I use a product called freemill, not too bad for free.
Here are the emblems finished.
Michael_Moore
Post by Michael_Moore »
Kevin, those look very nice!
FWIW, I made a stamp with raised letters and I'd never do that for a nameplate. I had to do a lot of nudging around of the letters to get sufficient clearance between them for the 1/16" EM. Doing the letters as pockets as you did lets you retain the proper spacing between them. The drawback is an EM won't give you sharp internal corners.
cheers,
Michael
Michael_Moore
A 1/16" EM can give nice results in a single-stroke font that is 1/2" tall, but this project didn't use a fancy font that needed sharp internal corners to look good:
cheers,
Michael
V8 BUG
Post by V8 BUG »
Thanks for the kind words guys. Michael, those gauges look very neat. Was that stick font from autocad? I have a program called deskengrave that does one line at a time. My freemill will only raster in x or y so no single line fonts for me just yet.
Kevin
Michael_Moore
You can get some single stroke TTFs from:
http://featurecam.com/general/support/engrave_fonts.asp
http://www.cambam.co.uk/forum/index.php?topic=1557.0
on the gauge I used Machine Tool Gothic Italic. I used RhinoCam (Visual Mill) to do the gauge.
cheers,
Michael
kapullen
Post by kapullen »
Kevin,
Those badges are sweet.
Do you project the numbers with the software
or form the dimples?
Mike yours are nice too. Really clean looking job.
Kap
Fadal Turn, Fadal Vmc 15, Prototrak 16 x 30 Cnc Lathe, Pratt and Whitney 16 x 54 lathe, Pratt and Whitney Vertical Shaper, G & E 16" Shaper, B & O Electric turret lathe, 36" Doall band saw,
Enco B.P. Clone, Bridgeport CNC Mill, Delta 12" Surface Grinder.
V8 BUG
Post by V8 BUG »
Kap, I create a plane a few mm above the solid and create the test on that. I then "cut" the sketch on a surface that is .5mm below the top surface of the solid, this way my letter cut bottom is contoured the same as the top of the tag. It is very friendly cutting that way.
Kevin
V8 BUG
Post by V8 BUG »
Recent creations on the tmc-1000
Wheel centers for my gmc suv. I got tired of the Chevy symbols on my winter rims. These are the first pieces to have 2 set-ups. The bottoms are hollowed out and are tapped 1/4-20 for fastening to the rims.
More to come....I have alot to do yet.
