I have recently acquired a Hardinge SuperSlant 4-axis machine
requiring 18.8 kva of 3-phase power.
I also have a 60hp inverter.
Does anyone have any experience using a vfd to produce 3-phase
for use in a CNC environment. It has been suggested that the
stepped nature of the 3-phase output (instead of pure sine wave)
may cause the computer to mis-clock, get programming glitches,
or just generally crap-out.
Any opinions or suggestions will be appreciated.
John R. Packwood
vdmmedia@arches.uga.edu
vfd use with CNC
Re: vfd use with CNC
John
It depends on the quality of the transformer on your power supply for the control and the Quality/Size of filter capacitors.
The controls generally convert incoming computer power to DC before using it in the circuts so wave form is meaningless .
If you are really concerned with a "dirty" VFD, then you may want to throw an isolation transformer in before the "control transformer" to get a better sinewave.
My experience with dirty VFD's is more with RF energy and it's effects. but we doubled our isolation area anywayto stop line surges
