cnc for dummies
cnc for dummies
With my new purchase of a lobo cnc mill to play with I was wondering if there any reading material that might be of interest or web sites that might help with the learning curve?
Re: cnc for dummies
programming
Re: cnc for dummies
There are two books on this website that are not bad.
(Look towards the bottom)
http://www.sq-1.com/index.html
I have a copy of both books...if they have not been updated some of the software
might be out of date. However I think I learned a lot from them.
www.chaski.com
Re: cnc for dummies
The first step would be to determine if the stuff you will be using recognizes G Code or if it is Conversational.
If G Code, what G Code and format does it recognize?
It all depends on the machine control.
Re: cnc for dummies
The G-Code interpreter used with the Lobo CNC controller boards is really quite basic - lines, arcs, rapids, etc, but no canned cycles. If there's anything more complicated than a few lines of G-Code, I use CamBam to generate G-codes, using just the default post-processor. Just let me know if you have any questions about specific codes supported, or look at the documentation included in:
http://lobocnc.com/lobopscnc.zip
-Jeff
lobocnc.com
-Jeff
lobocnc.com
