100 PPR encoder dial
This forum is dedicated to those Hobbyists Interested in CNC machining & 3D Printing in their home shops. (Digital Read Outs are also topical, as is CAD/CAM as it relates to CNC)
Mill/Drill
Post by Mill/Drill »
Found this on eBay. Might be incorporated into a low tech stepper motor control panel.
http://www.ebay.ca/itm/100PPR-6-Termina ... 2a39e68295
hammermill
Re: 100 PPR encoder dial
Post by hammermill »
Not sure but 100ppr is 3.6 deg per pulse kind of crude or am I missing something???
FLSTEAM
Post by FLSTEAM »
Not sure but 100per is 3.6 deg per pulse kind of crude or am I missing something???
Well yes you could be missing some gears that give the final drive something more like you are looking for. Just a thought.
John B.
Post by Bill Shields »
actually, that is a fairly common number used on machines.
Most controllers have a 'divide by' function built into the control, so the 100 PPR on the wheel can become 1000 or 10000 with the flick of a knob.
Since most controls work Metric internally, 100 ppr = 0.1 mm or 0.01 or 0.001 using the divide by function.
This is what I use on my Fagor based mill and have installed in several dozen others over the years.
