Marty,Thanks. I do have the covers. At the time the pic was taken I was still doing machine mods.Marty wrote:Very nice. I see you kept the original stepper motors? Do you have the covers for them? I still may have mine if you need them.
Yep. Still using the 100 step motors. They work just fine, altho I have an upgrade drive already worked
out that will fit within the existing covers. 3 to 1 belt drive.
Pic below shows the permanent setup before I moved to a new home.
If anyone is interested I have a solution to the tricky Z axis nut lubrication problem.
