Need stem extension for faucet made.
This forum is for those individuals or small business to solicit requests for Service from those members of our group. Machining, Foundry work, Sheet Metal work etc. This site makes no guarranty of work or represenation by the users of this site. It merely attempts to provide a place to allow individuals the opportunity to meet and discuss needs and capabilities.
Rob2049
Post by Rob2049 »
Type of Faucet: Jado 822/003/144 Wide spread with Knob handles. ( 5 years old ).
http://www.jadousa.com/designers/techni ... 22/003/144
Above link goes Spec sheets & Installation Instructions.
Part needed: Is what I would call a “stem extension”. That goes from the ceramic valve or cartridge to the knob handle. Jado does not sell this part ( they call it part of the handle that is not suppose to come apart ).
Overall Length of part: 7/8 inch.
One end has a 20 spline female end and the other end is threaded.
Spline end: 9/32 inch ID ( measured off the male part ). Depth of spline: 5/16 inch.
Threaded end: 17/64 inch OD. Length of threads: 19/64 inch. Number of threads: 6.
Material type: Copper.
What might work is to find a part with the 20 spline female end and then cut the threads in on the other end.
Need 4 but depending on cost may purchase 8 for a backup.
Thanks & Take Care!
Rob O'Halloran
5203 N. 24th Street, #204
Phoenix, Az 85016-3545
Ph: 602-224-9567 Tuesday – Wednesday 9:30 am – 3:00pm Arizona time.
Rob2049
Part has been made
Post by Rob2049 »
Part has been made.
Post can be removed.
Rob O'Halloran
