Hello guy's,
I am looking to get an idea of cost and time on eight pieces. Just a ball park per would be fine as I know that my drawing is VERY very bad.
I would need four total (two right, two left) of the plates and four flanges.
The radius corners can be what ever is easiest (they are just for looks)
If anyone is interested in doing this I will provide the specs I need as the picture is just a close example (the best I can do)
The step in the plate is just like the flange and when bolted together will hold a bearing.
Thanks,
PooK
Needing a few pieces made
Plates
I can give you a quote on the parts you need made. You can email me at
email address: rmercer23@nc.rr.com
Thanks Larry
Thanks Larry
