My new shop
Re: My new shop
There are ways to recover those pictures as long as you don't start using and writing other stuff all over the drive.
I've used a program from this company
http://www.easeus.com/
You can get the free download of the read only portion to see what it will/can recover. It builds you a list and then you can recover whatever you want to. May take 24 hours to run and do the scan though.Then you can pay (under $100?) for the actual recovery part (a patch if I remember right). It does need another hard drive to write the recovered data to though. No big deal with todays USB attached hard drives for under #100. You should have an external backup anyway.
The company is out of one of the asian countries and when i got the program they only took paypal. I was skeptical but desperate at the time so I sprung the money. Very happy customer. Have used the program a couple of times.
Re: My new shop
I did a system restore and the files were there, but nothing in them. I know there are programs for recovering them, but I will just take new ones. I am not real interested in the past anyway.
Re: My new shop
Just a update on my machine move. Took a while to figure out, but now I will always have a good way to lift heavy stuff. I did not have much wiggle room for height, but just enough. Cool thing is, (with the help of my tractor for beam placement) I can do it all myself. Metal muncher is over 4000 pounds easy.
Scott
Scott
- alphawolf45
Re: My new shop
Wow thats a real nice fabricating shop in a purty part of the world....
Re: My new shop
Yes it is!. We don't run from our sky around here. Really scary-tragic stuff down your way. I am sure a funnel cloud is killer to look at, but from a safe distance. (whatever that is?)alphawolf45 wrote:Wow thats a real nice fabricating shop in a purty part of the world....
Lightning hits every once in a while, but I have not seen too much up this hill. Other side you see a lot of trees hit ( Heading to Bend Oregon)
Re: My new shop
That's a great looking view and a great looking shop. That beam does have little wiggle room but should serve it's purpose well. What type of casters are on that metal muncher? What type of weight can they support?
Anyone ever use a rapid prototype specialist for a project?
Re: My new shop
I figure down the road the beam could be modified to extend up if needed. It did the job, and keeps me from looking for a fork lift.NorrisM wrote:That's a great looking view and a great looking shop. That beam does have little wiggle room but should serve it's purpose well. What type of casters are on that metal muncher? What type of weight can they support?
The casters came from my friend in Wyoming, and have no info on them. Really old, and were free too! They work well, and have a cast base to them. Takes a lot to move them, but that works for me. Mostly I just want to be able to swing the muncher around for longer stock if needed, and once in a while roll it out of the way to get my truck into the shop.
I added two things to the shop, and I am thrilled with them. One was free a metal bookcase, that I made into a shelf, and the other was a metal cabinet of of Craigslist. $55.00 worked for me. I like having my benches cleaned up, so I have room to work on things. I really am trying to clear out enough floor space for a lathe/and smaller mill of some sort. 24'X32' does not leave a lot of room when you have a plasma table hogging up space. Still I am really happy I can get all I need in there. The side benefit is, it's easy to heat.
- Site Admin
Re: My new shop
Nice shop Scott. Good to see you around. I've been scarce but staying busy....so what ever happend to Moe?
Re: My new shop
Nice shop, with a nice view Scott. Nice equipment too!
Looking forward to seeing what you make in there.
I live among those 25,000 people up by Harold V, who has been very kind to me, in my learning process.
If you have any questions about the sizing of your shop wire, from your main panel, I could probably help, it's my day job. Just PM me if you like.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
Re: My new shop
Marty,
we parted ways, down different forks in the road..
Yep, Harold seems to help a lot of people..
Shop wiring is done, and works like it should. My CNC plasma machine was kind of finicky before the upgrade. Thanks for the offer though.
