I found a melted wire connector and repaired but still nothing.
Purchased a new switch from littlemachineshop.com,after an hour searching was the only one I could find.
Rating is the same,but it has one less row of contacts(3 contacts per row) than my original.
The part number seems to reflect this (original= HZ10-10p/4 new=HZ10-10p/3)
I have been unable to find a diagram corresponding with what it looks like i'm working with,and don't fully understand they way these switch polarity.
Can I use this switch or do I need to track down a different one?
If somebody has a diagram or can assist in the wiring or where I can get a correct replacement F/O/R switch I would very much appreciate it.
I'm posting several pictures that will hopefully help in identifying the switch,lathe or proper diagram.
Two wires appeared to have been unused/disconnected,these could be to the light that does not work as i've never investigated why it doesn't.
Photobucket is giving me fits,so here is an old pic of the machine and maybe someone has an idea or diagram.
More detailed pics of old switch,wiring and new switch to follow.
