Lathe Following Chip Guard
ksierens
Post by ksierens »
In a effort to cut down on the chips flying everywhere on my lathe, I made a chip guard that is attached to the carriage of my Craftsman 101.21200 (6x18 Mk2) lathe. When I had the carriage off to drill and tap for the ways wipers I previously made, I also drilled and tapped holes on the back of the carriage so I could mount an indicator. I am taking advantage of that to mount the chip guard.
SteveM
Re: Lathe Following Chip Guard
Post by SteveM »
Very nicely done. Like how you put the stop in.
How did you curve (or where did you get) the plexiglas?
neanderman
Post by neanderman »
Truly nicely done!
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Dave_C
Post by Dave_C »
Very nice indeed!
Dave C.
ksierens
Post by ksierens »
SteveM wrote:How did you curve (or where did you get) the plexiglas?
Steve, I made a form out of 3 2x10's with about a 8 1/2" diameter. I heated the acrylic up in the oven on a cookie sheet at about 350 degrees until it started to bend, and held it over the form, covered with some tin foil, until it cooled.
warmstrong1955
Post by warmstrong1955 »
Great job.
I like the form trick! Very Clever!
Bill
SteveM
Post by SteveM »
ksierens wrote:Steve, I made a form out of 3 2x10's with about a 8 1/2" diameter. I heated the acrylic up in the oven on a cookie sheet at about 350 degrees until it started to bend, and held it over the form, covered with some tin foil, until it cooled.
Nice!
You realize that you could make more and sell them to us?
