Quick-Disconnect fittings for air brakes (Part # needed)
Anyone know the Manufacturer# or Part# for the plastic quick-disconnect hose fittings at LALS, and where they can be purchased?
I don't mean the bulkhead fittings, just the plastic "twist-on" fittings that connect the air line between cars. Thanks!
Re: Quick-Disconnect fittings for air brakes (Part # needed)
what do they look like?
Phil contact Ray in the roster. He would know. If not him then John DePhillips
Christopher P. Mahony
Los Angeles Live Steamers
1 inch scale member
1 inch scale member
What kind of connectors are we talking about? Are they better (and/or cheaper) then Clippard MQC screw on fittings?
Nick P.
Chattanooga, TN
Jesse Livingston's "Newbie"
Allen Models Mogul, #573
Backyard Rails/MDM F7A & B, Southern Pacific #6351
Too many other projects to think about.
Chattanooga, TN
Sorry for the delay, see attached photo...
Do those serve as 'break away fittings' also?
Thanks,
Pete
Thanks,
Pete
Just tryin'
Yes the do break away when the cars seperate
1 inch scale member
1 inch scale member
Ahhh. So those are used for "glad hands"? A short hose from each car and they meet in the middle? I seem to recall those fittings from a long time ago on a pnumatics project on a job..... trying to remember the name of the company...
Thanks,
Pete (new at this stuff)
Thanks,
Just tryin'
I hope someone comes up with the part nos. Looks like it could be really handy.
JB
JB
I think I found 'em!
http://www.cpcworldwide.com/Product-Lis ... ategory/43
The name fits with what I sorta remember and they look right....
Specifically:
http://www.cpcworldwide.com/Product-Lis ... roduct=187
Pete
Here is one half of the coupling (like shown in the previous photo):
http://www.usplastic.com/catalog/item.a ... &catid=926
Here is the other half:
Hope that helps!
Pete
Specifically:
Pete
Hope that helps!
Pete
Just tryin'
So, not exactly like a glad hand. You need a male and a female part. Not a real problem unless you swap direction of the cars.
JB
JB
No, not the same. However, if there is a bulkhead mounted female (or male) on the car ends, and a hose with two male (or female) ends, then the hook up is un-sexed. But the connector is not in the middle of the hose....
Where are the scale glad hands hidden??? Does no one make them?
Pete
Pete
Just tryin'
