Picture test
Get community help here, post test messages, suggestions etc. I will also document here changes that take place such as maintenance and upgrades.
Moderators: Harold_V, Marty_Escarcega
Marty_Escarcega
Site Admin
Picture test
Post by Marty_Escarcega »
Steggy
Re: Picture test
Post by Steggy »
Marty_Escarcega wrote:VFD enclosure with VFD mounted no wiring small.jpg
What was the size of the file from which you uploaded? PHP-BB seems to be truncating the file itself during the upload.
spro
Re: Picture test
Post by spro »
I appreciate the improvements to the Board. This definition issue may well be to software, don't know. I'm a dumber dinosaur. I'm sure many tests included sending your file out and back to you. Something has been occurring with the Net.
Reason: To remove political content
GlennW
Re: Picture test
Post by GlennW »
originally 5152 x 3864
Could it be Browser related?
I'm using Chrome and anything and everything I've tried seems to work.
Steggy
Re: Picture test
Post by Steggy »
GlennW wrote:DSC00023.JPG
Using Seamonkey, but have also tested on Internet Exploder. The key seems to be in the file size (not the image size) being truncated. What is the size of the file that you uploaded?
GlennW
Re: Picture test
Post by GlennW »
7.1 mb
SteveHGraham
Re: Picture test
Post by SteveHGraham »
Using a lathe to make a hole in an exhaust flange?
GlennW
Re: Picture test
Post by GlennW »
Yes, the other three holes are done from the top in the mill, but that one hole is obscured by the pipe and needs to be done from the bottom.
The holes were just being enlarged to fit over larger studs.
Flood cutting oil and carriage feed wasn't so bad either with stainless.
Steggy
Re: Picture test
Post by Steggy »
SteveHGraham wrote:Using a lathe to make a hole in an exhaust flange?
Borrowing and corrupting your tagline, if your only tool is a lathe, everything is a turning job. :lol:
Steggy
Re: Picture test
Post by Steggy »
GlennW wrote:7.1 mb
Interesting. Did you reduce it in any way before uploading?
SteveHGraham
Re: Picture test
I knew Glenn was not short on tools, so I wondered what was up.
GlennW
Re: Picture test
Post by GlennW »
BigDumbDinosaur wrote:
GlennW wrote:7.1 mb
No, I didn't do anything. Just pointed to it and it uploaded and worked as usual.
Here's a 1.3 mb, so size doesn't seem to affect it.
This is from home, which is running Chrome as well, though. The other was from my computer at work.
